Reply
MB200 with Orbi RBK50
V8burble
Follower
I’ve purchased an RBK50 router and Satalite together with an MB200 modem to replace my BT home hub 5. I have BT Infinity 2 to my home.
I’m stumbling to set it all up!!!
I have connected the MB200 and run it’s setup as a modem + router and when connected to my Mac it works fine connected via LAN cable.... I can access the Internet fine
I have also placed the Orbi router and satalite units in the house and started the quick guide setup for these... again all fine up to the point where the two units sync beautifully with a solid blue light on the satalite.
Then when continuing with the setup the Orbi can not connect to the internet.
Is this because the MB200 is also being a router? I’ve tried setting the MB200 device mode to modem only and reconnecting but still no internet connection on the Orbi.
Do I need to be doing something else on the MB200 setup other than just setting it to modem only mode?
I’m sure I’m not the first UK BT Infinity customer to install this Orbi. System??
Please help.... I’m no expert that’s for sure and it’s all gibberish to me
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: MB200 with Orbi RBK50
Couple of options,
Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router modem.
Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP modem on the Orbi router.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 408 views
  • 0 kudos
  • 2 in conversation
Announcements
