- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MIsmatching router/satellite firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
This may be a silly question... But my orbi purchased in december of 2017 from amazon and it has model number RBR40 for the router and RBS20 for the satellites. I see that there is a new beta firmware for the router that might help connection drops and reboots. But there is no corresponding firmware for the RBS20 satellites.
My questions are:
1. Is it odd that my firmware is RBR40 and RBS20?
2. Will there be a beta firmware for the rbs20?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: MIsmatching router/satellite firmware.
I will have to check if there is a beta firmware for the RBS20.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks that would be appreciated. Also is there any issue with running this combination of models?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
no you can mix and match the satellites with the router whatever works best for your home.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Here is the link to the Beta firmware for RBS20
http://files.netgear-support.com/go/?a=d&i=OGhLlDB9mQ
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
I have the RBR20 with firmware 2.1.4.10 and a satellite RBS20 connected via ethernet cable thru a TP-Link gigabit switch. The firmware for the RBS20 is V2.0.0.64 and when I try to check firmware to update to newest version the status says "Service unreachable" in the status column in the Firmware Update page.
Is this an issue becuase of the wire connection?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Just manually download the FW file for your RBS20 then manually install it to the RBS20.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK853 (Router Mode), Wired Backhaul and R8000 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
