Orbi WiFi 7 RBE973
Reply
Mac address filtering
Fritzjr1
Follower
I am thinking of replacing two Linksys E2000 WiFi/Wired routers that connect to a Verizon Fios Cable Modem/router with the RB50 system.  I currently keep a list of acceptable MAC addresses in the security table of the Linksys rounters as an additional security measure and just add/delete an address as needed.  I didn't see this capability mentioned on the website or elsewhere.  Can anyone confirm if the RB50 will allow me to continue to use this added security measure?  Thanks!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Mac address filtering
Yes it does its located in the security settings under access control.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1046 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
