Reply
Megasat SAT>IP Server 3 with Orbi
nibaz
Follower
I have a Megasat SAT>IP Server 3, it was connected via ethernet cable to my DSL modem/router (Fritzbox) which then broadcast the TV signal through the router's WiFi. Now I have a hooked up an Orbi system and deactivated the WiFi of the DSL modem/router. I tried connecting the Megasat IP Server to the Orbi ethernet pörts but I cannot see the IP Server on my network. Has anyone got a SAT>IP server working with the Orbi along with a DSL modem?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: Megasat SAT>IP Server 3 with Orbi
Hello nibaz
Do you have the modem bridged? if not are you running orbi as a access point?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 425 views
  • 0 kudos
  • 2 in conversation
Announcements
