Reply
Highlighted
Guide
Memory: RBK43 -vs- RBK33
Can anyone share with me what is the impact of having different amounts of memory in an Orbi router, and in its satellites?
Specifically, I am trying to compare the difference between the RBK43 and the RBK33.
Both systems have the RBR40 as the router.  (4GB flash, 512MB RAM)
But then things start to differ...
The RBK43 uses the RBS40 as its 2 satellites.  (each has 4GB flash, 512MB RAM)
But the RBK33 uses the RBW30 as its 2 satellites.  (each has 128MB flash, 256MB RAM)
What are the impacts of this difference in memory amounts?
I like the savings of the RBK33 versus the RBK43 (since I don't need ethernet ports at my satellites), but I don't want to noticeably degrade my wifi.
Any insights are welcome!!
Model: RBK33| Orbi Plug-In WiFi System, RBK43| Orbi AC2200 WiFi System
Message 1 of 18
Highlighted
Guru
Re: Memory: RBK43 -vs- RBK33
Performance would be one and the flexability to add more satelites to the 40 series system would be another...
My Setup (Cable 900Mbps/50Mbps)>CAX80(Modem Mode)>RBK853 v3.2.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 18
Highlighted
Guide
Thank you for your reply!
If possible, can you expand on what aspects of "performance" will be affected by the lower memory in the satellites of an RBK33 system versus an the satellites of an RBK43 system?
Will I see less coverage range?  Will I experience slower speeds?  Will I see more disconnects?  How does memory in SATELLITE units affect performance?
Also, you mention that the RBK43 system will allow more satellites to be added than the RBK33 system.
Can you expand on that please?  Is the RBK33 limited to the Router (RBR40) and two RBW30 satellites that make-up the RBK33?  Am I unable to add a 3rd RBW30 satellite at a later time?
I really appreciate your expertise and guidance!  Thank you for your help.
Message 3 of 18
Highlighted
Guru
Performance would have to deal with how many devices are connected, what devices are doing, things like streaming, gaming and operations like this can impact performance. Theoretically you can only have a certain amount of devices connected. Each device can take up more than just one connection. It can take up hundreds of connections to the internet. Having more and doing more with a router will depend on how much memory and CPU speeds will govern what the router can do and operate with.
For a small home with may two people, then the lower rated system maybe all thats needed. If you have a house hold with more than two people and many devices doing many things, then the higher model maybe needed.
You can find specs on most of the Orbi models here:
https://www.netgear.com/support/product/orbi.aspx
Message 4 of 18
Highlighted
Guide
FURRYe38 - Thanks anyway.
Message 5 of 18
Highlighted
Guru
Good Luck.
Message 6 of 18
Highlighted
Guide
Thank you.  Your guidance was invaluable.
Message 7 of 18
Highlighted
Guru
Hope you find something that works best for you and well for your needs. Futureproof is a good thing as well a long with the ability to grow.
Smiley Wink
Message 8 of 18
Highlighted
Guide
Thank you.  I am sure I can find guidance that will help me to make a wise purchase both for today and the future.  I know there is a lot of detailed information available for the Orbi.
Message 9 of 18
Highlighted
Guru
Smiley Wink
Message 10 of 18
Highlighted
Guide
And right back at ya' Furry!!!
When I get some good info, I'll reach out to you and share!
Message 11 of 18
Highlighted
Guide
Hey Furry, THANK YOU AGAIN!
I've just earned another badge because of you...thanx!!
Now I understand how all the badges are earned with so, so, so much guidance being offered!
Thank you!!
Message 12 of 18
Highlighted
Guru
Smiley Wink
Message 13 of 18
Highlighted
Guide
You're the FURRY BEST!!
Thanx for sharing those insights!!
Message 14 of 18
Highlighted
Guru
Smiley Wink
Message 15 of 18
Highlighted
Guide
Thanks again FURRY!
Message 16 of 18
Highlighted
Guru
Let us know what you decide to get and how it works out.
Message 17 of 18
Highlighted
Guide
Absolutely!
Message 18 of 18
Top Contributors
Discussion stats
  • 17 replies
  • 2284 views
  • 3 kudos
  • 2 in conversation
Announcements
