Reply
Menu design
KH_B
Follower
Menu design
I would like to designate DHCP beginnig at 192.168.1.21. Cannot find the correct panel toset this up. I did this on a router from another manufacturer without difficulty. Ijust need to find the correcr screen to achieve this function.
Message 1 of 3
Accepted Solutions
randomousity
Luminary
Re: Menu design
dc403157-f044-43df-81b3-f8d66886fedb
My Setup | Internet via TC8715D Cable modem, Bridge Mode, 200↓ 10↑ | Wifi Router Orbi RBK50 AC3000, Router Mode, Wireless Backhaul
Message 3 of 3
All Replies
Guru
Re: Menu design
ADVANCED > Setup > LAN Setup
Also review the user manual as well...
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Pg 77
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK50 v2.7.2.104(WW)/RBK853 AP Mode v3.2.18.1
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
randomousity
Luminary
Re: Menu design
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 636 views
  • 1 kudo
  • 3 in conversation
Announcements
