Peter_F's avatar
Peter_F
Follower
Jul 27, 2020
Mesh Wifi system management using a Mac app or browser instead of iOS/Android app
We are an Apple-only family and I am trying to find a Mesh WiFi system that can be managed from a MacBook instead of from an iPad or iPhone.  The main reason is that I want to be able to see what is going on when I am away, as I can connect to the MacBook using TeamViewer.  Obviously I can't do this using an iPhone, and anyway my iPhone will be with me!  Does this Orbi system have such an app for the Mac?  Or can you connect to it and manage it using a web browser?
1 Reply
  • I, too, am an "Apple-Only" guy. The ORBI can be managed via a web browser. The ORBI built-in GUI is primarily how I interact with my Wi-Fi and wired system. I am unfamiliar with TeamViewer but logging into your ORBI from a remote location will require opening a port (or ports) to allow such a connection. I recommend using a secure method for any remote connection.
    Other, more  expert folks will probably chime in shortly. Good Luck!
