Orbi WiFi 7 RBE973
Reply
Mesh
jeff424
Mesh
I currently have a cable modem and router supplied by Charter.  Connected to the router by cable are my desktop computer and two range extenders.  I have a long one story house with a full basement.  The range extenders are located in the ceiling of the basement - my preferred location.  They are both wired.  I would like to install an RBK23 system in the same place and configuration - wired and in the basement ceiling.  I would also like to keep my desktop computer wired to a router.
Questions:
  • Will this work?
  • I like the basement because the wiring is already there and I don't have to find space for the RBK 23 components on the first floor.
  • Will the signal penetrate a hardwood floor? - It does now with my range extenders.
  • Will I need to turn off the wireless function of my Charter router?
  • Are there better solutions? - I'm looking for a "unified" network because sometimes the portable devices don't switch to the best connection.
Message 1 of 6
Guru
Re: Mesh
Questions:
  • Will this work?----Yes, just make sure to put the orbi in AP mode or you'll be in a double nat. Or you'll need your charter box in pass through mode.
  • I like the basement because the wiring is already there and I don't have to find space for the RBK 23 components on the first floor.----Should work great. wiring in the satellites with a wired backhaul will make them function better in my experience.
  • Will the signal penetrate a hardwood floor? - It does now with my range extenders.----It should. It does in my place and i have hardwood floors.
  • Will I need to turn off the wireless function of my Charter router?----Up to you. If you've got the wireless spectrum, you should be able to space out the channels so they don't interfere. If they do interfere, you can disable them. But you won't want to use the same name for the charter wifi and the orbi wifi.
  • Are there better solutions? - I'm looking for a "unified" network because sometimes the portable devices don't switch to the best connection.-----there's always better solutions. But the orbi is a solid choice in my experience. Plus when you start getting "better" solutions, you start increasing the price you're going to pay for those solutions. You can go up to orbi AX solutions or even business class AP solutions. But again, $$$$.
Message 2 of 6
Guru
Re: Mesh
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Questions:
  • Will this work?
Message 3 of 6
jeff424
Re: Mesh
Thanks very much for the replies.  I now have a much better understanding of the problems and solutions.
Message 4 of 6
jeff424
Re: Mesh
Thanks very much for your reply.
Message 5 of 6
Guru
Re: Mesh
Hope this helps you in your endeavours.
Good Luck.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 775 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
