Reply
Model N4500 can i use this with Orbi system?
MJLau
Hi Can i use orbi with my old router N4500?
Message 1 of 4
Accepted Solutions
Re: Model N4500 can i use this with Orbi system?
yes , you would can run the 4500 as a router only and disable its wifi and run the orbi in ap mode behind it
Message 2 of 4
All Replies
Message 2 of 4
MJLau
Will this still give me the range i`m after?
Message 3 of 4
sure the range is the same weather the orbi is in ap or router mode
the n4500 what ever that is will do the routing and control everything , the orbi does what it does best and that give whole home wifi coverage using wifi backhaul
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2009 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
