Orbi WiFi 7 RBE973
Reply
Modem for RBK753S
Dubo
Follower
Modem for RBK753S
Just purchased ORBI RBK753S ( still in box ) &
Wanted advise on best modem to match with it ?
Currently using a Netgear C6300 combo modem router unit. Any recommendations ? Xfinity is internet provider.
Message 1 of 3
CrimpOn
Guru
Re: Modem for RBK753S
This is a good time to switch from a combination modem/router/WiFi to a "modem only" device. Preferably a DOCSIS 3.1 compatible modem.
(The C6300 does not support telephone service, so it appears that you do not have telephone service through Xfinity.)
I was not successful in finding a simple list of Xfinity compatlble modems. This is what came up:
https://www.xfinity.com/support/articles/list-of-approved-cable-modems
and this
https://approvedmodemlist.com/comcast-xfinity-approved-modems/
Message 2 of 3
Guru
Netgears CM series would be recommended.
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 660 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
