Reply
Highlighted
More than 8 hours on hold for RMA so far.
Woke up this morning to a completely dead RBR50. Sats are fine but the router doesn't turn on at all. Called in at 8am and spoke with someone who took my information, created a case, and then was transferring me to someone in the Orbi department.
That was 8 hours ago. Still on hold.
Model: RBR50| Orbi AC3000 Tri-band WiFi (Router Only)
Message 1 of 3
Highlighted
Guru
Re: More than 8 hours on hold for RMA so far.
@DarrenM
My Setup (Cable 900Mbps/50Mbps)>CAX80(Modem Mode)>RBK853 v3.2.16.6(Router Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P, EX7500/EX7700, XR450 and WNHDE111
Message 2 of 3
Highlighted
NETGEAR Moderator
Hello Paul
If you are still having issues with support PM me the case number if you have it or if not I can still look into the issue.
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 277 views
  • 0 kudos
  • 3 in conversation
Announcements
