- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Multiple problems- RBR-50
- Mark as New
- Bookmark
- Subscribe
- Permalink
I JUST SET UP THE ORBI RBR50 DEVICE AND I CANNOT GET MY PELOTON APP OR PANDORA TO RUN ON MY IPHONE WHEN I CONNECT TO THE ORBI NETWORK. ANY SUGGESTIONS?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Multiple problems- RBR-50
You may want to start at the beginning so people can help you. Technical experts need more information such as:
What type cable modem are you connected to?
What firmware does your RBR50 have?
How many satellites do you have?
Does your phone really connect to Orbi or do you just think it is?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, Youtube app runs fine. Peloton will start but the on demand videos will not play. Pandora also starts but music doesnt play.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I verified the firmware is at the most recent version (2.3.1.60) I have a UVerse router, model 5268acfxn.
The Orbi system was in router mode, I changed it to AP Mode. No difference. I turned off the wifi on Uverse router and it is now working.
thanks for your help
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you figured it out. Yes having two separate wifi sources in close proximity can be problematic. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Please mark your thread as solved so others will know.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I used different SSIDs for the UVerse Gateway and ORBI
