Orbi WiFi 7 RBE973
Reply
My Macbook Air is not connecting with my wifi router
AATCT
Tutor
I recently repaired my Macbook Air and now only can connect to my router in one area of the flat. I have two other Router satelites but not able to connect to them. The wifi signal will drop if I move away from one particular area. This only happens to my Macbook Air.
Message 1 of 5
Guru
Re: My Macbook Air is not connecting with my wifi router
What Mfr and model Orbi router are you using?
Do other devices conenct to the system ok?
Message 2 of 5
AATCT
Tutor
It is the ORBI RBR 20. This Macbook Air is the only that has a problem. I have another Macbook Pro and Ipad all work perfectly.
My macbook air screen was damaged and I replaced it. After replacing it, it only stays connect to the router in my study and the moment I stepped out from the study, it drops.
Message 3 of 5
Guru
Had the mac book air connected to Orbi before it was damaged? If, so I would have Apple or a Apple tech look at the mac book air again to ensure its fully working.
Message 4 of 5
AATCT
Tutor
Yes the Macbook Air was able to connect to the wifi previously and was fine even when I move around my flat. Now it seems to be stucked in the study. I have also checked the Macbook Air with Apple. Everything is fine.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1169 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
