Orbi WiFi 7 RBE973
Reply
My Netgear Orbi RBK50 satellite drops wifi speed after evert 2 to 3 days
Sozon
My RBK50 orbi stellite speed drops from 94mbps to about 40mpbs every 2 to 3 days.
When I connect to satellite via ethernet I get full speed of 94mbps.
I have a line of 100mbps speed and I get 94mbps on the router and main unti.
After I reset the orbi system or change a setting via orbilogin the speed goes up to 94mbps again for a few days and then drops back.
p.s I use orbi main unit  as access point (not as router).
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 8
Guru
Re: My Netgear Orbi RBK50 satellite drops wifi speed after evert 2 to 3 days
Message 2 of 8
Sozon
My firmware version is V.2.5.1.8
I have tried all below suggestions and patern keeps on coming back.
My sattelite wifi speed only (ethernet speed of the sattelite is fine) keeps dropping from 94mbps to abt 40mbps after 2-3 days.
One more thing I noticed is that wifi speed comes up again after changing any setting in the orbi interface (for example enable/disable MIMO or anything) probably because system restarts.
Message 3 of 8
Guru
Lets try updateing the FW on the system.
RBS first then RBR lastly, factory reset and setup from scratch.
https://community.netgear.com/t5/Orbi/RBR50-RBS50-Firmware-2-5-1-16-Update/m-p/1897955/highlight/tru...
Message 4 of 8
Sozon
May I ask why the system says that my firmware is up to date and there are no updates available?
Also may I please ask whether you are an authorized Netgear Support employee or just a user?
Message 5 of 8
Guru
Sometimes the system doesn't report newer FW. Users have the option of downloading and manually installing FW from NGs download site if they choose to do so.
Message 6 of 8
Sozon
Thank you for your reply.
If assume that if I install the new firmware I will not have to go through each individual device in my house and touch any settings, right?
Also is there a need for factory reset? in the case of factory reset as well do I have to manually connect again all my devices to my orbi?
Message 7 of 8
Guru
You shouldn't have to touch any devices.
A factory reset maybe needed if you seen continued problems. If you do, just reset the RBR and RBS and setup the SSID name and PW used as before. Your devices will reconnect again. I recommend doing the reset after the FW is appiled and setup from scratch on the RBS and RBR.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 797 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
