- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My RBR50 will not connect to internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My RBR50 will not connect to internet
Has a power OFF of the ISP modem and RBR for 30 seconds then back on been performed since?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Rafikix11 wrote:
My internet and router were working fine intil this morning when it wouldn't connect to internet. I tried resetting everything but it kept saying my password wasn't correct. Knowing this was wrong I tried a factory reset. Now it will not connect to internet. I know it's not my modem because I have connected to internet via ethernet cable through my PS4. Anyone have any answers? Please advise.
After the factory reset:
- How are you attempting to configure the Orbi (web interface or Orbi "app")?
- What happens if, after the factory reset, the Orbi is cabled to the modem and turned on (nothing else, just turned on).
* Is there a sequence of "ring light" that match the ones expected?
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean - Does the Orbi WiFi appear (the SSID printed on the product label)?
- Can a device connect to the Orbi WiFi using the SSID/password printed on the label?
- Mark as New
- Bookmark
- Subscribe
- Permalink
DOCSIS 3.1 eMTA
I'm guessing that's what you mean 🙃
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am getting a blinking white ring light.
It seems my devices will connect to router but no internet will come through.
On the Orbi app the setup seems to be going fine until it gets to the "checking internet connection..."
Looks like this
✅ Cables connected
❌Checking Internet Connection...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try using a wired PC or laptop connected to the RBR and set it up that way.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware?
others won't ask
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Rafikix11 wrote:
I was trying to use the orbi App to reconfigure.
Looks like this
✅ Cables connected
Please describe that white ring light in more detail. I just now powered up an RBR50.
Immediately, the ring began to blink white in very close to a one second pattern (on...off...on...off...etc)
At 50 seconds, the ring began to pulse (slowly on....slowly off....slowly on....slowly off...etc.)
at 2:30 seconds, the ring light went out.
