- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NBN with phone and Orbi RBK23
- Mark as New
- Bookmark
- Subscribe
- Permalink
A previous discussion (NBN setup with RBK20) suggests that Orbi will work with NBN if you 1) change the cat5 cable from the one supplied with the Orbi
2) plug the Orbi from the Internet port directly into the NBN Arris modem.
The problem with this is, if you also have a phone connection on NBN, this method will disable the phone. So there doesn't appear to be any way to get Orbi to work with NBN when using phone as well.
I've tried plugging Orbi into LAN port on ISP-supplied wifi router, and it doesn't work.
Any suggestons?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NBN with phone and Orbi RBK23
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@GSP99 wrote:A previous discussion (NBN setup with RBK20) suggests that Orbi will work with NBN if you 1) change the cat5 cable from the one supplied with the Orbi
Any suggestons?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the suggestions, but:
1) and 2) are not possible because I can't touch the ISP's modem. The modem is an Arris CM8200 supplied by NBN. Can't tell you the Orbi firmware because I can't get it connected to the new wifi network.
3) If I connect the modem directly to Orbi I lose the home phone connection, so that is also not possible.
It appears the only solution is to move the NBN connection point to get better wifi reception.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, the modem, you have is a modem only.
To check the FW version on the Orbi, connect a wired PC to the lan port on the RBR and use a web browser to log into the RBRs web page at orbilogin.com or 192.168.1.1.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
@GSP99 wrote:Thanks for the suggestions, but:
