Orbi WiFi 7 RBE973
Reply
NETGEAR Orbi RBK23 and NETGEAR Orbi RBK50 together?
Mrrs4
Follower
Will NETGEAR Orbi RBK23 and NETGEAR Orbi RBK50 work together? Setup with 2x NETGEAR Orbi RBK50, and put one or two RBK23 as satelite?
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 2
Guru
Re: NETGEAR Orbi RBK23 and NETGEAR Orbi RBK50 together?
You can use the RBS from the RBK20 series on with the RBK50 series system. You can not use the RBR20/50 as a satellite.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 916 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
