- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NG Orbi : Second satellites drops Wi-Fi speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have a 200/200 fiber line. My modem is connected with Orbi router and they are in the same place.
From the Orbi router a UTP (cat6) to a switch (NETGEAR GS105 5-port) from the switch to my second satellite that one is on the 2nd Floor, so its a wired satellite.
The problem now is when i do a speedtest its stops at 90/40 if do the test at the Orbi router i get my 200/200.
I added some info about my Orbi.
Some screens of my Orbi
https://ibb.co/PtWVF0P
https://ibb.co/xsw8p0C
https://ibb.co/BgRsqVV
https://ibb.co/qDpfCC6
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NG Orbi : Second satellites drops Wi-Fi speed
