- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
NVR to Orbi RBS50 satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: NVR to Orbi RBS50 satellite
If both the TP-Link and the Orbi are "routers", then they are each creating separate IP subnets.
This often leads to devices being "unreachable."
When you plug the NVR into the Orbi satellite, it should request an IP address from the Orbi. This will be different from the IP address it was getting from the TP-Link.
What is the symptom of "not working"?
This "Double NAT condition" is usually handled by making one of the routers into "not a router".
In this situation, the easiest solution would be to put the Orbi into Access Point (AP) mode. That way, the TP-Link will give the NVR the same IP address it was getting before and all devices should be able to find it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
