- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
Nearby device will not connect to satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: Nearby device will not connect to satellite
I do but a ring doorbell has a battery in it. It may be hardwired but the battery is still there and will last for months.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Just traded in my ring for a nest which does both 2.4 and 5. Got a great deal for $150.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Find a free phone app for signal strength for one of your devices. It might help you find the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CM1200 Modem | Wifi Router Orbi RBK853 (Router Mode), Wired Backhaul and RBK752 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What are you expecting?
A little more information will be needed here.
@Chris1984 wrote:
I am expecting the same issue!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Basically i have a nest door bell next to my orbi satellite (it is only 2 meters away) and the nest camera is connecting to my main orbi router that is situated over 10m away and is onanother floor. Moreover the connection is poor it is 30%.
Thanks
Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Thanks
Chris
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
So basically the orbi is connected to my ISP and the ISP modem i steh Technicolor TG789vac v2 - http://www.resqnet.co.uk/wp-content/uploads/2016/02/TG789vac-v2-Set-up-and-user-guide.pdf
The conncction between the orbi router and satalite is marked as good on the orbi app. so i guess that there is no issue between the orbi devices.
The neighbours wifi is wery weak signal.
WPA is - WPA2-PSK [AES]
2.4 ghz is on chanel 6
5 ghz is on chanel 40
Beamforming and MIMO are enabled .
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
If you reboot the RBR, leaving the satellite alone. Do any devices connect to the satelilte?
Also regarding your ISP modem:
This modem alredy has a built in router and wifi. This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- « Previous
- 1
- 2
- Next »
