- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need guidance on what models are needed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I recenty moved to Virginia, and my house has ethernet cable running throughout it. I want to use an Orbi Router at the Verizon Fios point of entry in the basement. I also want to feed the ethernet cables that are running throughout my house with the same Orbi Router.
On the main floor I want to connect another Orbi Router (RBR40) to one of the ethernet ports (effectively connecting an Orbi Router to an Orbi Router via ethernet). This will better allow me to hard wire entertainment devices (AppleTV and such). It should also give me a stronger WiFi signal on the main floor.
On the second floor, I plan to use the Satellites that I already have (RBW30).
Does anybody see an issue with this setup? If all looks good, should I buy another RBR40 for the basement?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your best option is to have another Satellite not a Router. If you want to have only one SSID throughout the house, then you need only to have one Router and couple of Satellites.
So if you already have the RBR40 and RBW30 then you just need an additional RBS40 or RBS20. The RBS40 will give you more Ethernet ports than the RBS20.
Good luck!
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Need guidance on what models are needed
And because I like pictures...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good luck!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the advice! With that setup I'd put the RBR40 (which I already have) in the basement and the RBS40 (which I'd be buying) on the main floor, correct? No issue connecting the RBR40 to the RBS40 via an ethernet cable? I ask because I looked at the back of the RBS40 and I don't see a designated spot to receive traffic... I only see that on the RBS50.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jthespartan wrote:
.......With that setup I'd put the RBR40 (which I already have) in the basement and the RBS40 (which I'd be buying) on the main floor, correct? ...........
Correct
@jthespartan wrote:
........No issue connecting the RBR40 to the RBS40 via an ethernet cable? I ask because I looked at the back of the RBS40 and I don't see a designated spot to receive traffic... I only see that on the RBS50.
RBS40 has 4 LAN ports (please see picture below from the product's data sheet). You will need to connect one of those LAN ports to one of the LAN ports on the RBR40 to have a wired Backhaul.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One final question... is it possible to go with a RBS50 instead of an RBS40 on the main floor (when using a RBR40 in the basement)? Having a tough timing finding a new RBS40... I can only find a new RBS50.
If that doesn't work, I have two choices... start from scratch with the RBK53 or buy a like new RBS40.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, RBS50 will work with your Router RBR40 but it will work exactly as an RBS40, that is with 2x2 backhaul instead of 4x4 backhaul since the RBR40 only supports 2x2 backhaul but that should be ok for the solution you plan to implement,
Good luck!
