Orbi WiFi 7 RBE973
Reply
Need help for RBR50 expansion options
m_chop
Follower
I have The RBK50 which is a kit that containing one RBR50 router and one RBS50 satellite. Can I:
  1. Expand this system with an add on?
  2. If so, what is the model and number I need to buy to add to this mesh?
Thanks
MC
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
Guru
Re: Need help for RBR50 expansion options
Can add up to 3 officially. Others reporting having 6 satellites.
RBS50 satellites is what you would need.
Message 2 of 3
randomousity
Luminary
Any of the RBS or RBW models should work. Basically, anything under "satellites" on this page (also pictured below).Capture.PNG
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1019 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
