- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Need help on downgrade RBR20 firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RBR20 is currently at the latest firmware of V2.5.1.16
If I were to downgrade it all the way to V2.1.2.18 (or even earlier version), do I need to downgrade it steps by steps or I can go straight to V2.1.2.18 ?
Any help would be appreciated, thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
As long as you have the firmware you can upload it to the router. You do not have to downgrade in steps. You will get a warning that the firmware is an older version than the current one. Just click through that.
Good luck. You may have to telnet into the router to turn off auto updating of firmware. That has been an issue for a lot of us. There are posts on the forum to help with that if needed.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Need help on downgrade RBR20 firmware
I've downgraded straight to the version and it does not brick the router 👍👍
However, my RBR20 still can't connect to Internet after trying a few older firmware 😔😔
