Orbi WiFi 7 RBE973
Reply
Need help on "bridge mode/access point" configuration
Eric52
Follower
A music server I just purchased requires a wired connection to my LAN. Also, the user manual requires the following on the LAN: "Wireless Access Point or a Wireless router set to a "bridge mode/access point" configuration." So, when I had set up my 2-node ORBI just using the quick-start default settings, did it automatically configure it in either bridge mode or access point configuration?  Or do I need to go into any admin menus and manually set it?  If so, does making such a change affect any of the normal LAN connectivity for all the other typical computer and TV-type devices in my home?
Thanks in advance for your help!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Accepted Solutions
Guru
Re: Need help on "bridge mode/access point" configuration
The default initial setup will be for Router Mode. You'll need to go into Advanced tab/Advanced settings/Router/AP mode. There you will see two modes, select AP mode. The system will reboot.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6427 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
