Orbi WiFi 7 RBE973
Reply
Nest Thermostat with Orbi - Unable to Connect
MelB
My Nest thermostat has always worked fine with my RBR50.  It is still connected to the network.  But the iPhone app no longer connects.  I looked at a report that shows the device as “blocked”.  How doI unblock it?
Message 1 of 2
schumaku
Guru
Re: Nest Thermostat with Orbi - Unable to Connect
Whatever report - do you find the thermostat blocked in the Attached Devices on the Orbi router Web UI (or the Orbi App, or the Genie App)? If yes, check the Orbi WiFi System User Manual p.52 ff "Allow or Block Access to Your Network". Similar control is available in the Orbi App resp. the Genie App, too.
A screenshot attached to the post where/how you see the report would help a lot.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1450 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
