- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nest Thermostat with Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ever since I installed the RBK50, the nest will not connect to it. Nest can't even find my router to connect to.
Any idea?
Thanks!
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well maybe it is dead. One of my nest protects the wifi failed and they replaced it. Thats why iwould try tech support they may just send you a new one.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nest Thermostat with Orbi
I use nest with no issues but had to downgrade firmware to 1.11.x series
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a Nest Thermostat v2 and v3 working fine with my Orbi with firmware 1.12.0.18 in AP mode behind a BT Smart Hub. The v3 is new but the v2 also worked fine with the Orbi in rouuter mode in earlier firmwares. As far as I understand it, the Nest only connects to the 2.4 MHz band.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you all. Will try to downgrade my firware tonight.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nest v3 can connect to 5G wifi. I have two of them and no problems with the latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've have tried all the suggestions with no luck. I have a 3 Gen nest themostat.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What security mode are you using? I am using WPA2-PSK [AES]. I also have the 3rd gen and has been working fine on both the old firmwarre and the new V2.0.0.72 firmware. When you go to connect it I assume it sees your network ok?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am using WPA2-PSK [AES]. Problem is Nest can't even find the router (It is not showing up in the nest wireless setup screen), all other wireless devices are working fine.
I am tempted to buy a brand new nest to try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried Nest tech support? I had to work with them on a Nest Protect that wouldnt connect. They ended up sending me a replacement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also have you tried rebooting the thermostat? Hold the ring down for 10 seconds. The screen should go blank. Then press the ring down once and it will start back up.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, tried resetting it couple times with no luck either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got a new nest gen 3 last night. It worked perfectly once I plugged that in.
Time to contact nest and see if they can replace it.
Thank you all!
