- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear 7300 will no longer connect to Orbi after Orbi firmware update V2.3.5.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have two Netgear 7300 extenders connected to my Orbi network. After completing the most recent Orbi firmware update neither extender will reconnect to the Orbi router.
The extenders recognize Orbi's wireless. I have reconfirmed that I am using the correct password. I have tried factory resets without success. The firmware for both 7300s is up to date.
Interestingly, the Netgear 7300 extenders will connect to another router without issue. Is anyone else experiencing this problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear 7300 will no longer connect to Orbi after Orbi firmware update V2.3.5.3
I believe there was a recent post about someone with a EX7700 that would no longer connect to Orbi.
I recommend you open up a support ticked and let NG know about this:
https://www.netgear.com/mynetgear/registration/login.aspx
Would be interesting to see if they connect if you disable WPA security on the Orbi system. Re-enable after testing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interestingly, the Netgear 7300 would not connect to the Orbi router even with password security turned off.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let NG support know about that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
