Orbi WiFi 7 RBE973
Reply
Netgear Armor is not avalible on Orbi
windowspace
Tutor
Hello everyone:
I have an Orbi RBK53 suit which contains one RBR node and two RBS nodes. I have updated all the firmwares to the latest version and updated the client APP on my mobilephone. But there is not an Armor option on my phone so I cannot use this new feature. Does anyone know the reason?
Thanks!
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 8
CrimpOn
Guru
Re: Netgear Armor is not avalible on Orbi
On the Orbi app, do you see a "Security" icon?  (Maybe you have to scroll down for it to appear?)
I, personally, have no interest in Armor, so I have not activated it.  My understanding is that the user has to log in to a Netgear account to activate Armor.  When I tap the "Security" icon, it brings me to a login screen (which I cancel out of).
Message 2 of 8
Guru
What FW version is currently loaded?
@windowspace wrote:
Hello everyone:
Thanks!
Message 3 of 8
Blanca_O
NETGEAR Moderator
Hi @windowspace
- May we please know the router firmware version?
- What is the Orbi app version?
- Please describe your network setup.
Blanca
Community Team
Message 4 of 8
windowspace
Tutor
Hello:
My Orbi version is V2.3.1.60 and my app version is 2.3.7.6
My network setup is Orbi as a DHCP client to access the Internet.
Thanks.
Message 5 of 8
windowspace
Tutor
Hello:
I have tried many times but the app seems running in limitation with few functions.
Message 6 of 8
DexterJB
NETGEAR Moderator
Hi @windowspace, please make sure that the Orbi is configured as a router and not in AP mode. The Armor feature will only work if the supported device is in router mode.
Dexter
Message 7 of 8
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might also try there.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1239 views
  • 0 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
