Reply
Netgear C7100V set up options with Orbi
mclaurin3
Follower
need to know what Orbi whole home mesh system will work with the netgear nighthawk ac1900 wifi cable modem router (model c7100v) for xfinity internet and voice
Model: RBK22| Orbi AC2200 Tri-band WiFi System,RBK30| Orbi AC2200 WiFi System
Message 1 of 2
Guru
Re: Netgear C7100V set up options with Orbi
It should using one of the suggestions:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 674 views
  • 0 kudos
  • 2 in conversation
Announcements
