Orbi WiFi 7 RBE973
Reply
Netgear Contacted me to Write A Review
loomis1975
Luminary
Netgear contacted me to write a review, which is fine, I just copied my review for Best Buy, but then they copied it into the clipboard and wanted me to post it at Amazon.  Link went right to the product page at Amazon, but only problem is, Amazon won't let me post a review for something I didn't get through their website (Got the Orbi through Best Buy).  So I couldn't do it, but I would be happy to.
Message 1 of 8
DarrenM
Sr. NETGEAR Moderator
Re: Netgear Contacted me to Write A Review
Hello Loomis1975
That should be fine if you posted a review where you purchased the device.
DarrenM
Message 2 of 8
UnCapitano
Apprentice
I can post it for you.  I actually posted a review on Amazon myself, even though I'd received mine from Best Buy.  Great job, Netgear, but now I need that extra satellite.
Message 3 of 8
DarrenM
Hello Uncapitano
Thanks for the review and the satelites should be coming soon keep a eye on your vendors website.
DarrenM
Message 4 of 8
GadgetGuy
Apprentice
Darren, do you have any info on the extra satellite pricing?
Message 5 of 8
itGeeks
Apprentice
Darren when will the single router be avalible? In my very small apartment I only need a single, Also how much will it cost?
Message 6 of 8
DarrenM
I do not have the info at this time.
DarrenM
Message 7 of 8
im not sure there would be any logic in just buying this as a router alone esp if its price would be around $200 , you could get the r7000 for the same and have better wifi and feature set , unless that is you intend to move to a larger place and then buy a sat later on
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4196 views
  • 2 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
