- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear NTP servers down?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Both my RBS50Y and my Orbi Router RBR50 are stating that they cant connect to the Netgear NTP server. I'm in New York on Long Island & this is the Warning: The Orbi Router failed to connect to NTP server, please check your internet connectivity or try another NTP server.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear NTP servers down?
Have you rebooted your ISP modem and the RBR to see if this changes anything?
Try using a manual NTP server.
My RBR50 in AP mode is reporting same:
Just tried time.nist.gov and that works. |
- Mark as New
- Bookmark
- Subscribe
- Permalink
@computersteve wrote:Both my RBS50Y and my Orbi Router RBR50 are stating that they cant connect to the Netgear NTP server. I'm in New York on Long Island & this is the Warning: The Orbi Router failed to connect to NTP server, please check your internet connectivity or try another NTP server.
Google found me this site that checks ntp servers:
https://keetweej.vanheusden.com/query_ntp.php
When I checked, time-a.netgear.com, time-b.netgear.com, and time-c.netgear.com all report status. You might check and see what it reports for you.
Perhaps it would be worth trying to use a different ntp server. Popular ones are listed here:
https://tf.nist.gov/tf-cgi/servers.cgi
The Orbi ntp server is set on the Orbi web interface Advanced Tab, Administration, NTP Settings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried. Still reporting the same thing. It’s something with @netgear servers. All my other devices using non-Netgear ntp servers are working (Windows, Apple)
I use Netgear's Time servers and have no issues. So it may be that a hub is down in your area preventing you from getting to a series of Domains/IP addresses. This happens sometimes here where they are Hurricanes around.
If it doesn't clear up, change to another server.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So, It seems to have gone away. Meaning its working now 😃 Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Mines still reporting it can't connect. I'll check it this a bit later.
