- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear ORBI RBK50 slow modem speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have gigabit service from ATT. When I test the speed on the modem/router AT&T supplied, I get the expected speeds (992 down, 930 up). When I test on the Orbi router which is just connected via Ethernet cable (and all the Wifi Radios on the AT&T device are turned off), I get ~500 down, 935 up. I have run this test many times and the router from Netgear is half the speed down. Why?
These aren't speed tests on devices, these are tests on the router/modem themselves via either the ORBI App or via AT&T app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear ORBI RBK50 slow modem speed
When you testing with the RBR in the mix, are you speed testing with a PC and a speedtest app on the PC or speed testing with the speedtest app on the RBRs web page?
What happens if you configure the RBR for AP mode and speed test?
Has a factory reset and setup from scratch been performed with out enableing QoS/Speedtest, Traffic Meter and Any access controls on the RBR?
FYI: @Blanca_O
@aec4444 wrote:I have gigabit service from ATT. When I test the speed on the modem/router AT&T supplied, I get the expected speeds (992 down, 930 up). When I test on the Orbi router which is just connected via Ethernet cable (and all the Wifi Radios on the AT&T device are turned off), I get ~500 down, 935 up. I have run this test many times and the router from Netgear is half the speed down. Why?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’m testing using the orbi app which is testing on the router itself. Not using speed test or anything like that.
When I test on the att router it’s 992 Mbps. When I test on the orbi 550 today.
The orbi is in AP mode.
Here is the att modem info
Manufacturer ARRIS
Model Number BGW210-700
Software Version 1.9.16
MAC Address 74:8a:0d:82:69:11
First Use Date 2019/06/25 15:16:33
Time Since Last Reboot 01:08:56:24
Current Date/Time 2019-08-05T23:05:25
Datapump Version A2pvbJ042w.d26r
Hardware Version 02001C0046004D
Legal Disclaimer Open Source Licenses
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Orbi app isn't giving good accurate information.
Try using Ooklas stand alone speed test app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The built in speed test app seems to have problems. I would open a support ticket and let NG know of your experiences:
https://www.netgear.com/mynetgear/registration/login.aspx
The suggested use of a wired PC and stand alone speedtest app will be a valid test to check to ensure the Orbi is working otherwise.
Good Luck.
