Orbi WiFi 7 RBE973
Reply
Netgear Orbi 2.2Gbps - AC2200/(RBK23)
pazobeach
Follower
I live in a 2 stories house (about 4000sq ft) and I am considering to buy the Netgear Orbi Whole Home Mesh Wifi System AC2200(RBK23). I have a modem/router all in one (Arris DG1670) provided by my cable/internet company (Spectrum) and I am wondering if the orbi mesh will work with that or do I have to buy a new modem as well?
Message 1 of 3
Guru
Re: Netgear Orbi 2.2Gbps - AC2200/(RBK23)
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 3
Guru
Any progress on this?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 880 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
