Orbi WiFi 7 RBE973
Reply
Netgear Orbi AC3000 Tri-Band Mesh WiFi System RBK50 - Poor network
Dee_Syd
Follower
Hi all,
i recentrly purchased RBK50 (ROUTER plus one satellite), I connected router to my Modem (I am using BELONG AUSTRALIA modem which comes with a NBN box).
i was able to connect the router and satellite but the speed has decreased significantly. the internet is good neat the router but satellite is hardly adding any range. i also tried to change the position of satellite but of no use.
any one facing issues?
also, can I use router as modem instead?
thanks and regards
Message 1 of 3
Guru
Re: Netgear Orbi AC3000 Tri-Band Mesh WiFi System RBK50 - Poor network
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
Message 2 of 3
CrimpOn
Guru
No, the Orbi is not a "modem". Never.
It would help to know which of Delong's modems this is (DSL? FTTP?  FTTC?)
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 530 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
