Reply
Netgear Orbi RB20 no longer working after switching off/on
George95
After being switched off and on, both routers are now always stuck on a magenta light, sometimes a blue light will come on for seconds but then go back to magenta instantly. All that happened was one was switched off and back on. I have tried rebooting both, syncing, nothing is working.
Message 1 of 6
Accepted Solutions
George95
Re: Netgear Orbi RB20 no longer working after switching off/on
Eventually got it to work after doing a factory reset, still took a while even then, purple light again but thankfully working in the end.
Message 6 of 6
All Replies
CrimpOn
Guru
It will help if you identify what the Orbi system is connected to (brand & specific model number of modem).
How long has this system been in use?  (If it is "brand new", then Netgear provides 90 days of "complimentary" telephone support.  You paid for it and might as well get what you paid for.)
Did it ever work correctly?
One of the units (the router) is connected to the ISP modem, and the other unit is a satellite, correct?
What device are you using to set up the Orbi?  (desktop connected with ethernet?  smartphone?)
Thanks
I love my Orbi.
Message 2 of 6
George95
1. Vodafone Broadband Modem.
2. Pretty sure more than 90 days.
3. Yes it has always worked.
4. One connected to router and then one satellite in my room, yes.
5. I’ve been using Wi-Fi for my iPhone, Ethernet for PC and PS4, none of which work now.
Message 3 of 6
Guru
@George95 wrote:
1. Vodafone Broadband Modem.----Which model?
You put magenta ring. Is it blinking or solid? Each mean different things. but its usually a variation of not getting an ip address. Whether its for modem-router connection or router-satellite connection.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean
Again, which modem modem is it?
if you directly connect to it, does it work?
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 4 of 6
George95
I don’t know model, not at home right now. It is always solid ring. The router is just generic one when sign up for broadband, not custom. The internet router itself is working fine, yes.
Message 5 of 6
George95
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 716 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
