Orbi WiFi 7 RBE973
Reply
Netgear Orbi VPN Woes
Virtech
I'm trying to get the VPN working through the  RBR50, have configured the VPN through the netgear interface and then downloaded the Windows config file.
I have the OpenVPN client running on Windows 10, when I try to connect I get in the Logs, "Enter management Password",,  not sure what this is?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Blanca_O
NETGEAR Moderator
Re: Netgear Orbi VPN Woes
Hi @Virtech
Welcome to NETGEAR Community!
- Do you have the latest firmware version (2.3.1.60)? If not, I suggest to update the firmware.
- What version is the OpenVPN client used?
- Are you using a Static IP for your router or Dynamic IP?
Blanca
Community Team
Message 2 of 5
Virtech
Hi to answer your questions below:
- Do you have the latest firmware version (2.3.1.60)? Yes it installed
- What version is the OpenVPN client used?  2.4.7
- Are you using a Static IP for your router or Dynamic IP? Static
The Orbi VPN is pretty much useless, I was connected at once stage using a previous firmware version but it was so slow it was unusable.
Chris
Message 3 of 5
Blanca_O
NETGEAR Moderator
Hi @Virtech
Our support team is looking into this issue and would like to work with you. Please check your inbox.
Blanca
Community Team
Message 4 of 5
ribadiscibadisc
Rif.: Netgear Orbi VPN Woes
Can you share the solution please?
I have the same problem.
Thanks
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1274 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
