- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Orbi Voice (RBS40V) replacement adaptor
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I bought my Orbi Router in USA which comes with Orbi Voice (RBR40V). And recently I moved to India. After few hours of usage in India, the Orbi Voice adaptor melted and stopped working. Then i realized the adaptor is marked as 100 - 120v. My bad, I ignored looking at the voltage label for Orbi Voice as i checked for main Orbi Router and it supports 240v, so assumed the same voltage for Orbi Voice too. Lesson learned.
Now, I dont find the replacement adaptor for my Orbi Voice (RBR40V). Please guide me to get a replacement adaptor, if not Netgear any third party works? Here is the voltate info from my Adaptor
AC Adaptor
P/N: 332-11039-01
Input: 100-120V ~ 50/60Hz 1.5A
Output: 19V --- 3.16A
Model: AD2003F10
Type: 107LF BAH
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Orbi Voice (RBS40V) replacement adaptor
Netgear doesn't sell replacment power adapters.
You just need to make sure the adapter you buy in india has a matching output. so the same 19v, 3.16amp, and same polarity.
A 3rd party adapter should work fine if those match.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@IamNaga wrote:
Thanks @plemans for responding. Sure, I will give it a try in local stores near me. The hardest part with online is finding the right polarity which i a not able to find any.
They are out there, believe me. The problem is in finding one.
The "voice" satellite is rare in having a 19 volt adapter. (It is also on the CBR750 Cable Modem Router.)That could be the challenge. They are, though, pretty common on laptops.
One option is to go for something that provides set of different tips. There are also multi-voltage, switchable polarity adapters.
You can also find adapters that proclaim that they are compatible with various Netgear devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
One other thing to keep in mind. Only polarity and voltage need to match. You can have HIGHER amperage because the rbs40v won't pull more power than you need. Just not less (or it might not be stable)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good point.
Fortunately, a laptop adapter should deliver plenty of amps for a router, even one with an audio amp built in.
