Reply
Netgear obi outdoor satillite wifi extender
Jo1165
Outdoor satellite does not power on.  This is he 2nd one we have purchased.
Anyone have an idea what the issue is?  We have gone thru recommended steps.
We are trying to sync it will a Orbi
Thank you
Message 1 of 5
Mstrbig
Master
Re: Netgear obi outdoor satillite wifi extender
Thank you
Power on meaning no power? Or power on meaning not connecting to router?
If no power, have you tried another outlet? If so did you purchase new?
Orbi RBK53 System/RBR50/RBS50/RBS50. + Orbi Voice RBS40V
RBK753 system/RBR750/RBS750/RBS750 + RBK853 System/RBR850/RBS850/RBS850
SXK80 — Orbi Pro AX6000 WiFi 6 Tri-Band WiFi System
There's always a logical answer, if you have all the facts!
Message 2 of 5
Jo1165
Yes we have actually purchased 2 units both new.  Now that the 2nd one is having same issue, (light is not turning on or blinking) I think that it is user error!  We did change the outlet/power source and put the satellite closer to the other base unit and the light/unit is still not turning on.
Thank you
Message 3 of 5
Mstrbig
Master
If you have no power light or top lights after pushing the power button on the back of the unit, and you have it plugged into a good power outlet, then they have to be defective.
Message 4 of 5
CrimpOn
Sensei
I agree with @Mstrbig .  Verify that the electrical outlet is "live" by plugging in something known to work. (light, radio, vacuum cleaner (ha)).
Then plug in the power supply and press the "power" button on the back (next to the WPS) button.
I am a little incredulous that two units fresh from the factory could be defective.  On other products, the power button has an "in" and "out" position that differ by only a fraction of an inch.  Do you detect different "on"  and "off" positions in the RBS50Y switch?
I love my Orbi.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 249 views
  • 0 kudos
  • 3 in conversation
Announcements
