Orbi WiFi 7 RBE973
Reply
Network Map
aruit
Guide
Network Map
My current setup is an Orbi Router with 3 Satellites.
Two Satellites are connectes to the Router and the third Satellite is connect to another Satellite.
The whole system is functioning OK, none of the Satellites or Router have a warning light.
In the Orbi App (2.2) this is correctly displayed, but the third Satellite does not have a green but a orange light and is also not selectable.
All the other items: INTERNET, Orbi Router and the two Orbi Satellites, which are directly connected to the Orbi Router have all a green light and are selectable.
Why is the right functioning third router an orange light?
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System, RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 1 of 7
Accepted Solutions
aruit
Guide
Re: Network Map
Problem solved in new Orbi App 2.2.4.397
Message 6 of 7
All Replies
Guru
Re: Network Map
Message 2 of 7
DarrenM
Sr. NETGEAR Moderator
Re: Network Map
Have you tried to power reset or resync that satellite to the router? Also make sure all  units have the same version of firmware.
DarrenM
Message 3 of 7
aruit
Guide
Re: Network Map
Yes, all units, Router and three Satellites are the same firmware version.
I have done a power reset of this third Satellite, but with the same result.
Message 4 of 7
DarrenM
Re: Network Map
I may need to get you in contact with support I have sent you a PM.
DarrenM
Message 5 of 7
aruit
Guide
Re: Network Map
Message 6 of 7
Blanca_O
NETGEAR Moderator
Re: Network Map
Hi aruit,
We appreciate the update and glad to know that it resolved the issue.
Blanca
Community Team
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 11799 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
