- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Network error - can't connect orbi correctly
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello everyone,
I started to install the Orbi RBR50 in a new house. And I had everything set up for a perfect configuration. But I realized that the hour wasn't accurate: maybe we're not on 2019 november... After a few investigations, I saw that the Orbi router couldn't make profit of the modem connexion. It's able to share Internet to the devices, and it says for itself : ERROR not connected, or detecting... leading nowhere.
Any advice ? In the former config, everything was fully functionnal. I tried a factory reset and the common rebooting processes recommended.
Thanks for your help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Gateway sould be the same as what is set on the modem. Usually 255.255.255.0
Your DNS is incorrect. It should be 192.168.1.1 or you can input other DNS addressses, 1.1.1.1, 9.9.9.9, 8.8.8.8 or your ISP actual DNS addresses as well.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Network error - can't connect orbi correctly
- Mark as New
- Bookmark
- Subscribe
- Permalink
The modem used is a Freebox mini 4K (I’m in France). I set the Orbi router in router mode or AP without any change (on router mode, no internet connection at all. Now, on AP mode, which is the most convenient in a French case I guess, the internet connection passes through the Orbi set up, but the Orbi devices can’t connect itself)
- Mark as New
- Bookmark
- Subscribe
- Permalink
So the RBS are not connecting to the RBR in AP mode?
Yes if your ISP modem has a built in router already, AP mode would be recommended. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR and RBS are connected together. WiFi signal is covering the entire house and every device makes benefit of it.
Thus, the Orbi set itself is unable to access internet. Unable to connect to NTP, or firmware update. Orbilogin says ERROR: not connected (this affects only the Orbi set)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since your ISP is a router as well, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
How did you configure AP mode, using Dynamic or Static IP address configuration on the RBR?
What is the LAN IP address string of the modem? 192.168.something.something?
Yellow internt port on the RBR is connected to the back of the ISP Modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried to keep the IP inside or outside the adress list provided by the Freebox DHCP server of the Freebox, without any change.
Modem IP : 192.168.1.1 (as usual)
Orbi RBR IP : 192.168.1.101 (...1.102 for RBS)
Yellow port connected to the switch of the Freebox (ISP modem/router)
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the pool size of the modems IP address pool. If you use static IP on the RBR, it should be out side.
Be sure you filled in the Gateway and DNS values as well for Static.
Even Dynamic, should have got you internet access thru the RBR to the modem.
Be sure the modem isn't blocking anything as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The pool size is 192.168.1.2 -> 192.168.1.99
The Orbi set is out of it indeed.
Concerning the gateway and other, everything is set this way (and fully functionnal on other devices) :
subnet mask : 255.255.255.0 (should be 255.255.255.3 ? ISP modem is 192.168.1.1, and DNS are 192.168.1.254 and ...1.253)
gateway : 192.168.1.1
DNS server : 192.168.1.254 and ...1.253
As long as I can, the modem is not restrictive in any case. I even tried to whitelist the Orbi IPs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems that the default DNSs in the Freebox were wrong.
I didn’t think that… and then it works perfectly.
It wasn’t such a complicated issue but hard to find.
Thanks a lot for your help!
PS: I changed the DNS server on the ISP modem, and the Orbi… advice for the next guy who read this topic!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it's working now. Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
