- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Networking dropping after firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an RBR40 Ordbi Router, and the network keeps dropping. Not just losing internet access, but dropping connectivity all together. Has anyone else experienced this? I don't think it is an ISP issue as the whole WIFI network goes down. Should I do a factory reset? Any other thoughts?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Networking dropping after firmware update
Is the Orbi system operating in Router or AP mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello- The firmware version is V2.5.1.16. The modem is a Arris TM1602. We haven't had a problem until today, seemingly after the firmware update. Orbi is in Router mode (I believe). Home is 3,000 SF, and the satelitte was within 30 feet. However, I've unplugged the satellite to see if that was the problem. Couple of WiFi neighbors nearby.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has a factory reset and setup from scratch been performed since last FW update? Something to try..
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't done that, but I will. We were using Circle for parental controls. Wonder if the fix NetGear is trying is causing a problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset and this time, don't enable Armor or Circle and see.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to make a back up configuration to file.
Also try a factoy reset and setup from scratch next time after a FW update if you encounter problems.
Enjoy.
@80AM33 wrote:
I was having lots of issues after the 2.5.1.16 update. Most of my WiFi devices wouldn’t connect I.E. phones, smart switches etc. I tried using the Orbi app but it isn’t very feature rich, so I ended up logging directly into the router via 192.168.1.1. I looked around and didn’t see anything amiss but this thread gave me the idea to check out the parental controls. They were both off, so I turned one on, hit apply, then turned it off and hit apply again. Did the same to the other parental control option. After that everything connected automatically and my problems were solved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
