- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New 2.3.5.26 for rbk23. Anyone download or get issues yet?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyone?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New 2.3.5.26 for rbk23. Anyone download or get issues yet?
Seen some posts about it...might search the forum for that FW version string to see for yourself.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I download the software and try to install it I get the message "The disk image file is corrupted" Any ideas? I have tried downloading it again and get the same message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No.
What browser are you using?
Try a different browser.
Be sure to unpack the .zip files before trying to manually update FW.
@KiamaraKid wrote:When I download the software and try to install it I get the message "The disk image file is corrupted" Any ideas? I have tried downloading it again and get the same message.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have rbr20 and my pings got much worse. from 20ms to 170ms. I cannot figure out how to fix this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is the Orbi system operating in Router or AP mode?
How are you testing pings? Wired or wireless?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Has a factory reset and setup from scratch been performed since last FW update? Power OFF The ISP modem for 30 seconds then back on then walk thru the setup wizard after doing a factory reset?
@mrbyte wrote:i have rbr20 and my pings got much worse. from 20ms to 170ms. I cannot figure out how to fix this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I think I have an issue outside of the orbi atm. I did a ping from cmd and it was good. Not so good from speedtest even though the machine on the wired is getting 10ms and the machine off the backhaul is getting 175ms even though the ping to router is 3ms.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Lets follow up on your new thread post:
https://community.netgear.com/t5/forums/replypage/board-id/Orbi/message-id/70894
