- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware 2.3.5.30
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware 2.3.5.30
@AFD wrote:.......... Same disconnection problems in my case , regarding cameras because they are so far from the main router and it supposed them must be connected to the satellite . .......
- What happens if you switch off the cameras and turn on again, will it then connect to the nearest node (router/satellite)?
- Have you waited for some time to see if the cameras will roam by themselves to the better node? It’s the camera who should choose to which radio signal to connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware 2.3.5.30 is an absoolute disaster. My orbi system was getting disconnected from internet time to time. Lets say twice a week or a little more often. In order to fix this I went ahead and upgraded the firmware to 2.3.5.30, now it keeps rebooting every 2 hours or even less. I tried to capture the traffic to see whats going on with wireshark and did not see anything obvious. Netgear please fix this. I cannot return this product because, I have been using it for a little more than a year.
Netgear, please fix this mess. I am a software engineer in a big software company any this is not how a product is developed. You guys simply making a hardware and push it out there with fancy new features without even testing it much. Please stop creating new models and work a little on reliability.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's a disaster , also WiFi is unstable . Let's see if I have some time today to rollback . For the moment, status is : all the devices connected to the main router with the mentioned problems .
- Mark as New
- Bookmark
- Subscribe
- Permalink
@AFD wrote:
I didn't perform any action from my side to perform the update . I assume it was an auto update .
Do you have another router in your network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It was a manual update. It was an attempt to fix my ongoing isssues with the earlier versions. Now I reverted the upgrade. Now it takes 15hours to 48 hours to go unresponsive 😞
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah, unfortunately.
It was requiring twice a week regular manual power cycle. Because of the new firmware I am now closely monitoring the "debug" page and it tells how long the router was up. Probably it was always like that earlier and I was not aware about the debug page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Start testing with the following Steps
1 - Start disconnection (turn off-on) of each device thta supposed to be connected to the satellite (more than 20 devices)
2 - Verify the connections
3 - Depending on the results 1-2 go to factory reset and reinstall 2.3.1.44 (manually)
4 - Restore the previously config file saved 2 months ago .
Thanks for all the collaboration and support . Im going to keep you informed about the results
By the way , it seems that unstable wifi is better now (I dont know why , because I didn't perform any action , but let's see)
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's best to start by doing a factory reset on the system and setup from scratch after updating FW.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 I have a question for you. I noticed you have a lot of experience with the ORBI and your advise would be much appreciated.
I have an ORBI RBR50 with one satelite RBS50
I have followed your suggestions from other posts disabled Daisy chain, set it to 40hz only, MIMO and so on. It works great without disconnects perfectly, except when my ISP goes down and then back up. That disconnects start all over. When I send out a ping through command prompt lets say ping www.ibm.com -t.. After lets say the 10th try, the ping would either go above 1000ms or straight up Request Time out and then back to normal and after few more pings does the same thing. Now the only way I have found for it to work is if I turn off my modem, router and sat, and then turn on the modem, wait till I get a couple of lights out of 4, turn on the rbr50, wait till it turns on and start blinking as if it is trying to sync and then turn on the satallite. If I don't follow it through exactly, I have to redo it all over again. Any suggestions?
P.S I have done factory reset and it works until the power goes out or the ISP is having issues and it does it all over again
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the Manufacturer and model of the ISP modem? Built in router here or stand alone modem only?
Kind of sounds like the ISP service line needs to be looked into.
I would download pingplotter.com and install on a wired PC. Connect it directly to the ISP Modem with out the RBR online. Run some plots to pingplotter.com and let it run for a while if you can. See if it picks up any errors or Pack Loss along the way.
Ensure your ISP as checked the service line up to the ISP Modem.
If a cable modem, be sure to use good quality RG6 coax cabling.
Ensure there are no coax cable line splitters between the ISP service box and the modem.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
@MishoA wrote:@FURRYe38 I have a question for you. I noticed you have a lot of experience with the ORBI and your advise would be much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Spectrum 400mbps package,using my own cable modem, Netgear CM500, and it worked without any issues when I used it with my NETGEAR Nighthawk X4S - AC2600. I had to replace it because of the range. Definitely the range between the rbr50 and rbs50 is about 30 feet or slightly more and the sq footage of the house is about 3150. I tried setting the channel to 1, 6 and 11 for the 2.4 ghz for the wireless devices but the thing is that I am plugged in directly to my satellite with an ethernet cable and was seeing the disconnects. I will do as you suggest connecting directly to the modem and try out pingplotter. Also, definitely no splitters or anything like that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you seeing problems with a wired PC connected to the RBR?
@MishoA wrote:I have Spectrum 400mbps package,using my own cable modem, Netgear CM500, and it worked without any issues when I used it with my NETGEAR Nighthawk X4S - AC2600. I had to replace it because of the range. Definitely the range between the rbr50 and rbs50 is about 30 feet or slightly more and the sq footage of the house is about 3150. I tried setting the channel to 1, 6 and 11 for the 2.4 ghz for the wireless devices but the thing is that I am plugged in directly to my satellite with an ethernet cable and was seeing the disconnects. I will do as you suggest connecting directly to the modem and try out pingplotter. Also, definitely no splitters or anything like that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Problem solved(??) for the moment , status follows
This is the Method I used in my case
1 - Factory reset
2 - Manual installation Firmware 2.3.1.44
3 - Load Configuration file from Backup
4 - Testing everything with old firmware (OK)
5 - Manual installation Firmware 2.3.5.30
6 - Turn OFF/ON all the devices that supposed to be connected to the satellite
7 - Testing everything since 2 hours ago (seems to be ok)
Let's see what happen . Firmware 2.3.5.30 (up and running) .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Keep us posted on how it goes. A factory reset seems to help resolve some issues. Also manual load of FW files is good too.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since I did the steps I mentioned in my earlier post, it has been stable and haven't seen any issues. Unfortunately, I was so annoyed and forgot to do the obvious and connect to the RBR directly. When the that occurs again, I will defintely do that first and let you know. Thanks for the advice!
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MishoA wrote:Since I did the steps I mentioned in my earlier post, it has been stable and haven't seen any issues. Unfortunately, I was so annoyed and forgot to do the obvious and connect to the RBR directly. When the that occurs again, I will defintely do that first and let you know. Thanks for the advice!
Sorry forgot to quote the correct post
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Up & Running with 2.3.5.30 .
Almost 2 days with no (bad) news . Everything seems to run fine with no noticed issues (until now).
Satellite Devices are connected as expected .
Cameras running ok
IR/RF remote controls , devices and RF lights are operating as expected . (RF is posted because the remote controls are connecting to Orbi wia WiFi and send RF signals to different devices)
Keep you posted in case of problems .
Thanks to everybody for helping and supporting
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for letting us know. Glad it's all working for you now. I knew it would.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Thanks for letting us know. Glad it's all working for you now. I knew it would.
Enjoy.
IF you knew that, perhaps you can work on shorting up the troubleshooting process. Still trying to figure the wifi channel and neighbors question.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MishoA wrote:It works great without disconnects perfectly, except when my ISP goes down and then back up. straight up
I've seen something like this before with a personally owned modem. Unfortunately was never able to resolve it. Do you have option to put the modem and RBR50 on UPS power. This would only prove that power cycling the modem is or isn't causing the problem.
