- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware Notification
- Mark as New
- Bookmark
- Subscribe
- Permalink
For the past three days (2/11/2020) my IOS app has been giving me a notification that new firmware is available for the RBR50. I go into the app and do a check for new firmware and nothing is available. Next I go into the web interface of the RBR50 and do a check there. Also no new firmware available. I checked the download section on the Netgear site and do not see any firmware newer that the 2.5.1.8 that I have been running for weeks.
Anyone else getting this notification?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Firmware Notification
Make that four days in a row -- got another new firmware notification.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@BigRune wrote:
Strange behaviour by NG. I got the notice, and then it was gone a couple of days later. You either release or don’t 👎.
I have a suspicion that these "new firmware" messages are driven not by new firmware, but by an invalid value in the Orbi internal parameters. When I dump the Orbi parameters, there are over 1,800 of them. Many are pretty obvious, but a lot of them "could be anything, who knows?" I think the Orbi "app" is retrieving some values from the Orbi and comparing them to values from the Netgear web site and inferring, "There must be new firmware. Put up a message."
I don't have any iOS devices, and these "firmware update" messages do not appear on the web interface or my Android app. When this message shows up, does it actually list a firmware release number, or simply say, "New Firmware."
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Saw another post that one user had seen v2.5.1.8 in the FW check section. NG may have posted this version to the auto updater servers and now being seeing as an available upgrade. It's a minor upgrade so NG isn't forcing it to anyones system. It's your choice if you wanna upgrade or not. I and others are using it and its stable and works well. Some may need a factory reset and setup from scratch if you encounter problems after you allow it to update your system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My Orbi app has quit the notification of a new firmware when none was available. I have done nothing to fix this (not even reboot) so I'm thinking that Netgear must have done something to stop the notifications as they were happening every single day.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Of after a period of time if the user doesn't follow up with the upgrade, the notifications just stop.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not the case for me since I already had the latest firmware installed. I can see your point if the firmware was out-of-date. Plus if what you said was true, everyone would be getting the notification to upgrade for 5 days or more until it "timed out."
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well at any rate, you should be on v2.5.1.8 for now. If you need more help and information about the Orbi app and it's notficiations, please post here:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you are correct - I have been on 2.5.1.8 since the day Netgear released it. That was not the issue though. Thanks anyway.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And yes, I can google and download any fw outside the Orbi software functionality and then manually upgrade or downgrade. But I think most users, like me nowadays expect the router software to inform them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's a very good point. If there is newer firmware available, Netgear should at least let you know and then let you decide if/when you want to install it. Now Netgear doesn't even let you know about a new firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sometimes I do get FW update notfications via email. Also get notifications in the FW update check on the RBR. Again, when NG posts new FW to there update servers, if it's a major update, then NG seems to push these or will push these out automatically on Orbi systems. Any MINOR FW updates are posted to the servers or the download web page, these may show up at notifcations in the RBRs web page, however these minor versions are at the users choice to update or not. These are not pushed by NG. Users can also keep an eye here in the forums and on the direct download page on NG support site for new FW updates. Theres many ways to check for updates. I like to eye an eye on the download web site.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes indeed that is the way Netgear USED to do it. Now they don't even give a notification for any new firmware -- major, minor, it just doesn't matter. The only way I know is to go to download section on Netgear's web site and compare the version there with what you are running. That's something that the normal person who knows little about networking would probably never do. Maybe that's good in a way due to the major failures in new releases.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I guess the support cases went too high and they changed their mind. Anyway it is kind of sad having a new router where new firmware dont show up in the new firmware check.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Jetdrive wrote:Yes indeed that is the way Netgear USED to do it. Now they don't even give a notification for any new firmware -- major, minor, it just doesn't matter. The only way I know is to go to download section on Netgear's web site and compare the version there with what you are running. That's something that the normal person who knows little about networking would probably never do. Maybe that's good in a way due to the major failures in new releases.
From what I've seen, I still see FW updates AVAILABLE when I login into the Orbi web interface (if there are any) I don't use the app. IMHO updates that appear in the web interface are for the BETA Test Group, i.e. those that want to see if it works or feel that must upgrade. In that case, IMHO, NG should be paying you to test their FW.
Othwise leave your network alone and let NG push what they call major updates to you, no action on your part.
