- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
New - NetGear Orbi 20/40 Series Firmware Version 2.3.0.28
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New - NetGear Orbi 20/40 Series Firmware Version 2.3.0.28
Everything works fine with my cable modem and router now except I cannot get the firmware update to work right. I have downloaded it many times using a different browser each time with the same result. It goes through the download process ok but when I select "unzip all", it asks where to save it, I accept the destination that comes up, then it just takes me back to the same page where I chose to unzip it. The same two files are there, the notes and I suppose the other is the upgrade. I don't know what I'm supposed to do from there. There are no instructions, nothing comes up telling me what to do after I select the unzip all. Someone suggested to read the manual for my devoice, I did that several times before getting on this help forum, it does not give instructions other than download the file and unzip it-nothing else. That is why I an stuck. If I double click on the upgrade file, it says it is a corrupted file.
If I just knew what I am supposed to do after I unzip it, I could possible move on from here. I would think something would open up telling me what the next step is or instructing me to do something with the unzipped file/upgrade.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have downloaded using several different browsers. After I select "unzip all", a page opens asking me to select the destination for the files, I accept the choice already there, then it just takes me back to the page where I chose to unzip the files. NOthing else come up telling me to doa nything furthere, nmothing looks different than when this page first opens when I download the upgrade. If I'm suppoised to do something from there, I don't have instructions telling me that. I wouldn't know what steps to take next. Nothing in the user manual for my device gives me further instructions. It just says download and unzip. What next? How would I know if it actually unzipped? When I right click on the file, it says it is corripted, no matter which browser I use to download it. Last used was IE11. I think that was the fourth one used.
I apologize for niot getting this, I just don't understand what steps to take after I select unzip and acept the destination for the files.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try reading this message, and those around it.
Solved: Re: RBW30 - Firmware 2.3.0.4 - NETGEAR Communities
Also read this:
How do I manually update the firmware on my Orbi WiFi System? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
On you have the files downloaded, as @michaelkenward mentioned and provided a link on how to manually update FW, unzip the downloaded files first. You can put them any where. Windows has a built in unzip program so if you right click on any of the .zip files you can select "Extract ALL" Follow the instructions there. Once the files are unzipped. Then log in to the routers web page and use the MANUAL FW update section and navigate to the location where the unzip files are at.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
every thing was working just fine with v2.2.1.210 however one i have updated to 2.3.0.28 everything went mad as below :
- all Satellites are going up and down "no more stable connection"
- Backhaul Status is updated ever 5 to 10 secounds (config sync ==== > status ==== > config sync ==== > status ...etc)
- android app doesn't show my Satellites connected (sometimes 1 or 2 or 3 but it's not stable with every refresh) which wasn't the case beofre FW upgrade
once i have downgraded again to v2.2.1.21 , everything is working back again as expected.
note : i have been testing this for 2 weeks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Whats the distance between the RBR and RBS's?
Was a facory reset performed on both RBR and RBSs?
Others haven't seen this issue:
- Mark as New
- Bookmark
- Subscribe
- Permalink
the distance is arround 13.1234 feet (4 meters)
and yes facory reset performed on both RBR and RBSs
- Mark as New
- Bookmark
- Subscribe
- Permalink
13 feet is too close between the router and satellites. 30 feet minimum to start. The RBR can cover around and up to beyond 30 feet alone depending upon building materials.
- Mark as New
- Bookmark
- Subscribe
- Permalink
i can increase the distance , yet i need to understand why it works with FW "V2.2.1.210" but not with latest one , if this is the real cuase
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad it working well. Thanks for letting us know.
What is the distance between the router and satellite(s)?
@DickDuke wrote:
No problems to report, but I thought that people reading through the community posts might find it helpful to know that the Firmare Update to 2.3.0.28 can be done without issues. My current setup consists of an RBR40, 2 x RBS20, 1 x RBW30. I used the manual update process after first downloading and expanding the firmware appropriate to each device. First updated the RBW30, than the 2 RBS20s, and finally the RBR40. All satellites were able to synch again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem is a Rogers branded Hitron.
Satellites are between 20 and 35 feet.
The RBW30 is kinda my “bonus” satellite. I could get by without it, but it gives me a slightly better connection in the bedroom.
Its a a bit overkill for the size of my condo, but the condo is two floors, with rebar concrete floor, and steel studs in the walls.
In retrospect the RBK50 would have made more sense, but I’m not ready to spend that much money all over again, for no performance gain.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok. Hopefully will work well. Keep the distances at 30 feet. The RBR can cover a good range.
- « Previous
- 1
- 2
- Next »
