Orbi WiFi 7 RBE973
Reply
New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
LoboTommy
Luminary
Re: New Orbi RBR50/RBS50 Firmware Version 2.3.1.48
at this moment, I'm not allowed by family to diconnect the running wirless from the FMG, so i just plugged the orbi into one of the ports in the FMG. But nomally when the Orbi runs smoothly, it is solid bridged.
Distance when connectin now is about 30 feet, as the router is on the other side of the living room of to the PC.
When in full bridge mode - what setting of the RBR is correct? Router mode or the other?
I am now manually forcing v44 on the satelites, and keeping that on the router (i dont need japanese)
Message 101 of 171
Guru
Ok. so normally when you have Orbi running, you have the modems WIFI disabled when not bridged? This needs to be disabled on the modem if you have the Orbi running.
Yes when modem is fully bridged and wifi disabled, Router mode should be selected on the RBR.
Possible if the satellites were behind on FW then his maybe the reason they were not conneting. RBS have to be updated first before the RBR and be on the same version of FW or RBS can be on a more current version while the RBR can be on a older version of FW. RBS can't be behind in FW versions from the RBR.
Message 102 of 171
LoboTommy
Luminary
text diagram... lets see
see atached file for setup
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 103 of 171
LoboTommy
Luminary
SO, one satelite is up an running. Shutting it off, and start working on the nest. Taking 20 minute brake now to pick up GF in town
Message 104 of 171
Guru
Ok, that gives us conformation of the configuration. Thank you.
So after getting the RBS updated to v44. Factory reset just 1 of them. Turn OFF the others. When you see the top led pulsating WHITE on the RBS, Press the sync button on the RBR then press sync button on the 1 RBS while in the same room as the RBR. Give up to 5 minutes and you should see the top led on the RBS turn BLUE...Lets see if we can get to this point. Smiley Frustrated
Message 105 of 171
Guru
Yay. Ok you got the process. Keep us posted. I'll go get some lunch now. Smiley Tongue
Message 106 of 171
LoboTommy
Luminary
So, when trying to connect the second orbi, it "connected" but in status it said "config sys", ring turns amber, and log says
[DHCP IP: 192.168.1.4] to MAC address 78:d2:94:36:f5:5d, Tuesday, April 23, 2019 19:17:51
[WLAN access rejected: incorrect security] from MAC address 7e:d2:94:36:f5:5f, Tuesday, April 23, 2019 19:16:16
[WLAN access rejected: incorrect security] from MAC address 8a:d2:94:36:f5:5d, Tuesday, April 23, 2019 19:16:05
[WLAN access rejected: incorrect security] from MAC address 7e:d2:94:36:f5:5f, Tuesday, April 23, 2019 19:16:04
[WLAN access rejected: incorrect security] from MAC address 8a:d2:94:36:f5:5d, Tuesday, April 23, 2019 19:16:03
[WLAN access rejected: incorrect security] from MAC address 7e:d2:94:36:f5:5f, Tuesday, April 23, 2019 19:15:56
Message 107 of 171
Guru
Did you factory reset the RBS then try to re-sync?
Message 108 of 171
LoboTommy
Luminary
yup
Message 109 of 171
LoboTommy
Luminary
should i do the "genreate"  in the backhsul topology now as well? or was it enough the first time?
Message 110 of 171
Guru
Try a reboot on the RBR. Power OFF the RBS then back on then press the sync buttons. IF this fails on the 2nd RBS, move on to the next RBS.
Might try the generate new PW for RBS process as well...
Someone else with this similar issue not to long ago...
How complex is the admin and Wifi PW on the RBR?
Message 111 of 171
LoboTommy
Luminary
Wifipassword is the standard that comes along with the RBR20.
Admin PW is as follows  Ipconfig12345 (only using different letters)
Message 112 of 171
LoboTommy
Luminary
you said something about reserving the IP adresses for the RBS's. how do i do that?
Message 113 of 171
Guru
Ok, lets change the PW for the wifi SSID name on the RBR save and reboot. Lets make that something different. I know it shouldn't matter however maybe something is happening here. I always change the WIFI pw to something different other than the default one. You may need to re-sync the 1st one...worry about this later.
When you get a RBS connected fully, yes do a address reservation on the RBR under Advanced tab/Setup/LAN Setup, save and apply. Then add the next one.
Message 114 of 171
LoboTommy
Luminary
keeping the original SSID AND password from the RBR is actually the main difference i have made this time. Thougt i get them all up and running, than change the SSID to a new one I havent used before. Same with the passwords.
Message 115 of 171
LoboTommy
Luminary
So far, for every RBS connected, I have factory reset the RBS twice, it connects (finnaly) turns blue, sometimes amber, and i see now i have used the wrong colorscheme here all the time. Prior to this post, everytime i have typed Amber, I have meant the color Magenta. (Is it ANY excuse that I am norwegian?)
Typically, it flashes white, then turns magenta, I then hit sync (again) after "setup failed" message appears, and try again. With or without factory reset. Suddenly i turns blue, stays for a little while, turns back to magenta, stays like that for a few minutes, before turning blue again.
I wish there was a logfile describing what processes it tries to do, and where it fails.
Message 116 of 171
Guru
I have seen it where it turns blue the back to magenta then blue again.
So you now have every RBS connected and at BLUE?
Set up IP address reservations for each of them. This will help keep them connected and from IP address conflicts.
Message 117 of 171
LoboTommy
Luminary
Moment of truth, turn them all on. Can i get them all to sync stable?
Message 118 of 171
LoboTommy
Luminary
#off topic:
how do you get your "setup" to be visible in every post?
Message 119 of 171
Guru
I would turn them on one at a time, get BLUE before turning on the next one.
Message 120 of 171
Guru
Do you mean my signature?
@LoboTommy wrote:
#off topic:
Message 121 of 171
LoboTommy
Luminary
They have all turned blbue now, I moved them to their loactions, and turned them back on, and all synced up. I tried to allocate the channels, set channel 13 for 2,4ghz and channel 48 for 5g, as those are clear from traffic from neighbours.
Next now is new SSID and new password.
Message 122 of 171
Guru
Awesome...finally.
So momenth of truth, if you had to do this again, do you remember what you did? LOL. Smiley Tongue
Message 123 of 171
LoboTommy
Luminary
I was in heaven too soon. Took them lesd than 5 minutes to jump magenta. Then blue. Then magenta etc. No internet. Have to use my phone and 4g to update you now...
Message 124 of 171
LoboTommy
Luminary
Yes. Cannot locate where to insert signature in the setup...
Message 125 of 171
Top Contributors
Discussion stats
Announcements
Orbi WiFi 7
