- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Orbi firmware 2.1.2.18 update issues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New Orbi firmware 2.1.2.18 update issues?
Ever since 2.1.2.18 my RBR50/RBS50 AP Mode setup will not go above 10-20Mbps download on any device I test from (tablets, phones, laptops). I have verified via wired connection my internet is functioning properly (120/10). The devices can be connected on 2.4 or 5Ghz, it doesnt matter just slow speeds all around.
My patience is at an all time low with this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:Ever since 2.1.2.18 my RBR50/RBS50 AP Mode setup will not go above 10-20Mbps download on any device I test from (tablets, phones, laptops). I have verified via wired connection my internet is functioning properly (120/10). The devices can be connected on 2.4 or 5Ghz, it doesnt matter just slow speeds all around.
Hang in there kid. I had mine in AP mode and got fast speed so I know it can be done.
Others will likely come up with other suggestions but here goes my take.
1) Make sure that the firmware on both the router and sat unit(s) are the same.
2) I would disconnect any sat unit that you have and start with just the router
3) Unhook all cat 5 cables from the Orbi router except for one that goes from your computer to the Orbi router
4) Turn off all wireless devices (Android, tables, phones, TV's, DVD players) that would likely want to connect to the Orbi
5) Power cycle the cable modem, router, Orbi and computer
6) After power up and waiting 4 minutes, check the Orbi.
Make sure that everything looks OK
(only Orbi and PC connected, all have IP addresses, etc)
6) Run your speed test. If not high speed, then I suspect
A) Maybe bad cat 5 cables - Try swap out what you have
B) Orbi might be bad - wait for others for suggestions before swapping out
C) The router up ahead of the Orbi might not be configured properly - possibly
D) Something else you might have failed to mention in your post - more than likely
You have a router ahead of the Orbi in AP mode?
Networking is like a bowl of cherries.
You don't want to eat the stems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
1) Good suggestion but they are both the same, 2.1.2.18
2-5) I'll give it a go
6) I ran a speed test directly from Orbi router itself (Advanced -> Setup -> Qos) and was a perfect 120/10 speedtest. Which means the orbi-> router is clean (wiring issues for instance) and my router itself is functioning properly
6D) Just to add, I am a network engineer... troubleshooting network issues is something I have been doing my entire career. I am human and may have missed something but this is a simple network setup and sectionalizing the issue has shown me it is orbi.
Given what i have seen on these forums I would imagine it is more likely the firmware than a user issue at this rate. Netgear QA has not been exactly stellar.
- Mark as New
- Bookmark
- Subscribe
- Permalink
>> 6D) I would guess that you have run tracert command based upon you being a network engineer. What were the results up to where you connect to your IP host provider (next hop just outside your cable modem)? Anything stick out?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple things:
1) traceroute (mtr actually as it looks nicer 🙂 ) have looked clean, nothing to indicate a problem
2) given that speedtests from the Orbi itself and via wired are fine than I would not expect an issue on my router/fw with my ISP.
Again the only issue I see is with wifi devices that cannot seem to break this 20Mbps barrier no matter if its on 5Ghz or 2.4ghz and no matter the device.
Here is an iperf test result between a wired linux host in my network and a laptop on wifi (Macbook pro on 5Ghz), bit better than speedtest (slightly over 20) but still terrible:
$iperf3 -c 192.168.1.11
Connecting to host 192.168.1.11, port 5201
[ 4] local 192.168.1.103 port 50124 connected to 192.168.1.11 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 3.46 MBytes 29.0 Mbits/sec
[ 4] 1.00-2.00 sec 2.72 MBytes 22.8 Mbits/sec
[ 4] 2.00-3.00 sec 2.71 MBytes 22.7 Mbits/sec
[ 4] 3.00-4.00 sec 2.68 MBytes 22.5 Mbits/sec
[ 4] 4.00-5.00 sec 2.71 MBytes 22.8 Mbits/sec
[ 4] 5.00-6.00 sec 2.71 MBytes 22.7 Mbits/sec
[ 4] 6.00-7.00 sec 2.73 MBytes 22.9 Mbits/sec
[ 4] 7.00-8.00 sec 2.69 MBytes 22.5 Mbits/sec
[ 4] 8.00-9.00 sec 2.70 MBytes 22.7 Mbits/sec
[ 4] 9.00-10.00 sec 2.75 MBytes 23.1 Mbits/sec
[ 4] 0.00-10.00 sec 27.9 MBytes 23.4 Mbits/sec sender
[ 4] 0.00-10.00 sec 27.9 MBytes 23.4 Mbits/sec receiver
To the same iperf server again but this time wired, to show it can handle up to 1Gbps:
[ 4] local 192.168.1.222 port 50210 connected to 192.168.1.11 port 5201
[ 4] 0.00-1.00 sec 105 MBytes 880 Mbits/sec
[ 4] 1.00-2.00 sec 112 MBytes 940 Mbits/sec
[ 4] 2.00-3.00 sec 112 MBytes 940 Mbits/sec
[ 4] 3.00-4.00 sec 112 MBytes 940 Mbits/sec
[ 4] 4.00-5.00 sec 112 MBytes 941 Mbits/sec
[ 4] 5.00-6.00 sec 112 MBytes 940 Mbits/sec
[ 4] 6.00-7.00 sec 112 MBytes 941 Mbits/sec
[ 4] 7.00-8.00 sec 112 MBytes 940 Mbits/sec
[ 4] 8.00-9.00 sec 112 MBytes 940 Mbits/sec
[ 4] 9.00-10.00 sec 112 MBytes 940 Mbits/sec
[ 4] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec sender
[ 4] 0.00-10.00 sec 1.09 GBytes 934 Mbits/sec receiver
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple things:
Since you can't get the speed on neither WiFi 2.4 nor 5Ghz and wired is OK, I would suspect bad router. I have no other ideas at this point. Perhaps someonce else can chime it. All I can say is that it did work for me in AP mode. Hope you find solution.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Couple things:
Appreciate the help. I'll try the old factory reset, reboot everything, etc, etc. I would be surprised if its hardware as it was working great prior to the recent firmware update but things break sometimes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyone know if a new Beta Firmware coming?
- Mark as New
- Bookmark
- Subscribe
- Permalink
This blows! System with 1 satellite was rock solid for months. Then 2.1.* came out. Getting tons of disconnects, not sure if it's just satellite or main router but have had to unplug main and satellite a few times to get it to work again. Cannot even connect via app or desktop that is plugged in with a hard line. This is crazy...
Basically, missing out on Olympics because we have no internet. Just nuts....
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try going back to firmware
wrote:This blows! System with 1 satellite was rock solid for months. Then 2.1.* came out. Getting tons of disconnects, not sure if it's just satellite or main router but have had to unplug main and satellite a few times to get it to work again. Cannot even connect via app or desktop that is plugged in with a hard line. This is crazy...
V2.0.0.74
- Mark as New
- Bookmark
- Subscribe
- Permalink
How do I disable auto firmware update after going back to 2.0.0.74?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That used to be a method known to block auto updates. It no longer seems to work. I'm lucky enough to be running Orbi in AP mode behind a proper router with firewall capability. I'm blocking all traffic generated by the Orbi units.
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:
wrote:
The Eero network does continue working after losing internet connectivity. The only issue I have with Eero is the complete lack of IPv6 support, which is becoming vital since IPv4 addresses have been exhusted. The backhaul between Eero’s is only a maximum of 600 mbps, vs 1.7 Gbps for Orbi, and more than 1 Gbps for other networks.
However, I have found Orbi Pro and Eero to be the most reliable mesh networks, and I’ve tried most of them all.Well, if you use the eero in bridged mode as an AP, it will pass the IPv6 stuff transparently. So, while the eero as a router doesn't currently do IPv6, if you have it in bridged mode and have a "main" router that does handle IPv6, then you've got IPv6. The R7800 that I'm using is just fine with IPv6, so there you go *smile*.
I've verified that eero does support IPv6 in bridged mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
+1
Added Block ALL from Orbi Router and Satellite to WAN traffic on my upstream checkpoint firewall. Now it' stuck on .74 firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So outside of using it in AP Mode and block traffic with another router, there is no way to block the auto update since Telenet doesn't work anymore.
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:So outside of using it in AP Mode and block traffic with another router, there is no way to block the auto update since Telenet doesn't work anymore.
As far as we know that is the current situation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
What's really crazy about all of this is that based on the comments from the last few months, there are a bunch of us who had relatively rock solid Wifi until the more recent updates. Let's hope the next FW release will give a much more reliable experience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yup for me it was rock solid until first update after the .74 update, then it sucked, then I went back to .74 for a week and it was solid and now it is spotty again so it is definitely firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I rolled back to .74 2 days ago and it's been nice and solid. I am logging in every day to check to see if it had updated, so far it stayed.
When you say it's spotty, is that still on .74?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nope it is great on .74, zero problems. The problem is it will continue to check the firmware and upgrade you at some point, I guess I will roll back now and see how long I can go back before it upgrades. I got auto upgraded to 2.18 and that is when the problems started again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
wrote:Yup for me it was rock solid until first update after the .74 update, then it sucked, then I went back to .74 for a week and it was solid and now it is spotty again so it is definitely firmware.
And what's funny for me is that I had random reboots with .74 but since 2.1.2.18 I've been rock solid. Uptime is basically since the day after the firmware was installed, except for a power blip the ouse had a few days back. I did update my Android devices to beta play services and turned off uPnP but other than that, I'm loving Orbi lately. I just hope the NEXT firmware doesn't break things.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I wanted to wait a couple of weeks before posting about my upgrade to 2.1.18.
I have a Linksys WRT1200AC running OpenWRT as the router (wifi disabled) and the Orbit and 2x Satellites as AP.
- Daisy Chain Enabled
- Beamforming, MU-MIMO & Fast Roaming Disabled
As I mentioned in a prior post I have a raspberrypi (stationary, not roaming across the system) monitoring that the three Orbi devices are up and running. Monitoring among other things is pinging the 3 Orbis, checking that the 6 SSIDs are broadcasting (3x 2.4 Ghz + 3x 5Ghz), that different stationary wireless and wired devices on my LAN respond to ping, that DNS is working and that pinging 3 different internet hosts is successful.
I have had no issues for 2 weeks in a row, no reboots, no SSIDs drops, or lack of connectivity to my LAN or the Internet. WiFi speed and coverage are outstanding.
I briefly tried to enable fast roaming and the reboots and disconnection started happening again, so in order to keep peace at my home, I have not touched the configuration anymore.
Roaming does not work well, when moving around the house I find myself turning off/on my cellphone wifi so it picks the closest Orbi.
Though the Orbi system can be considered by many a configure-and-forget device, not being able to enable key features due to its instability¸ which I expected and paid to work, like fast roaming or beamforming it is disappointing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought this ac3000 rbr50 plus 2rbs50 last weekend from costco. I have no android phones/boxes. Last night Computers lost connectivity and iphones and ipads crwaled. Found this pos autoupdated to 21218. Already feeling that this is garbage. I have 80 more days to decide if I should return it. Already considering Google mesh to replace this junk.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@KU1234wrote:Bought this ac3000 rbr50 plus 2rbs50 last weekend from costco. I have no android phones/boxes. Last night Computers lost connectivity and iphones and ipads crwaled. Found this pos autoupdated to 21218. Already feeling that this is garbage. I have 80 more days to decide if I should return it. Already considering Google mesh to replace this junk.
Have you tried the new firmware, v2.0.1.4:
https://community.netgear.com/t5/Orbi/OrbiOS-MR-2-1-issues/m-p/1506307#M23649
Apparently the new 2.1.* features have been reverted, and auto-update from this latest firmware version is turned off. So if it works for you, it will stay until "further notice".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thsnk, but...Re: New Orbi firmware 2.1.2.18 update issues?
Thanks Roger.
With this revert, I hear the ethernet backhaul is also reverted.
The distance between the router/satellites may cripple the 5G bands, making it monoband system, unworthy of $500 pricetag.
Netgear is not doing a good job of making most of a capabe-scalable-product.
Quality of the software and lack of enough testing before release are to blame.
