Orbi WiFi 7 RBE973
Reply
New Orbi firmware 2.1.2.18 update issues?
kennyj
Re: New Orbi firmware 2.1.2.18 update issues?
@kennyj wrote:
Updated to the new firmware about an hour ago.
Attached devices all reporting ok except for Ring (reporps connection type unknown).  It now seems to take a bit of time for the attached devices to populate.  Sat. reported as not connected but about 12 seconds later it reported good.  This was not the case with the prior beta 211 software which populated the devices instantaneously and correctly.   Will monitor.
Same for me on Ring but a power cycle on Router + Sat took care of that.  Needed to wait about 5 minutes for things to update on the connections.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 126 of 335
Gtramsey2000
Guide
Still getting disconnects where the orbi even disappears from the available WiFi connections altogether.
Anyone know what the last stable version was? I’ve resigned myself to having to do a manual roll back and stop automatic updates.
Message 127 of 335
u26336
Initiate
Indeed, same problem here, satellites are going down several times a day (I have google home, android 8, google chromecast, ...)
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 128 of 335
Blcklab
Apprentice
So waking my phone this morning rebooted the satellite. I checked statisitics pahpge.
Looks like the router rebooted shortly after midnight. No idea why. I have a system uptime of 7:30 and backhaul time of 7. Does that mean it took 30 minutes just for the backhaul to reconnect?
Getting a velop this morning. Hopefully Netgear sorts this out and I'll give my orbi to my daughter. Currently I would feel right even giving it free to some one else.
Message 129 of 335
larryindublin
Luminary
@DScone wrote:
This update has been solid for me so far. Thanks Netgear for your hard work. Keep the updates coming.
I’m 2 days and 19 in to using this latest firmware. So far, no reboots. I do have an Android phone (7.0) and also a chrome cast. I’ve kept the chrome cast turned off since it’s a known, unfixed problem. So far, seems pretty solid. Main complaint is it seems to be very biased toward using the Router vs satellite. I have a satellite maybe 6 feet from my wireless thermostat and it still connects to the router that is upstairs and across the house.
Message 130 of 335
budy
Luminary
Yeah… I do have the same issue. A couple of my 2.4Ghz clients connect from upstairs to my router on the groundfloor, instead of the satellite upstairs. I am think about further reducing the 2.4GHz radio power… Currently, I do have both radios on both devices set to 50%, maybe tweaking them to 25% will mitigate this behaviour.
Model: RBK40| Orbi AC2200 WiFi System
Message 131 of 335
wooties
Star
not sure how solid it can be if you have to disable devices on your network to get it to work.....
I've unplugged my 2 chromecasts, and google home and still have reboots. Not sure if i'll ever buy Netgear again.. and that makes me sad because it's awesome tech when it works.
Message 132 of 335
larryindublin
Luminary
Pretty easy actually. It’s a google problem that would require a workaround fix from Netgear. I’d rather Google fix it for good. That said, would be nice if Netgear WAS responsive enough to add some sort of optional fix for this, something that could be toggled, until google fixes it for good.
Message 133 of 335
shifty-key
Here is what i have and what i did. i have one RBR-50 and two RBS-50's...
They were all auto-updated to 2.1.1.16 from 2.0.0.74. Broke everything. Reverted back to 2.0.0.74. Telnetted in and disabled auto-update. Then i manually updated router from the zip file to 2.1.1.18 and updated the satellites from the admin page.
Done. No issues so far.
Message 134 of 335
tucsontico
Virtuoso
I did exactly as you did. Firmware 2.1.1.16 had issues so I rolled back to 2.0.0.74 for stability. Yesterday I took a chance and manually updated to 2.1.1.18. Satellite first, then router. While it isn't written in the Netgear "How To" file, I turn off all my devices (or put them in airplane mode) while I apply the firmware updates. Additionally, I reboot my cable modem immediately following the firmware install. I then bring all the devices online one at a time. I don't want to jinx it, but my system has been rock-solid for over 24 hours with no reboots or buffering issues (streamed two movies last night via Netflix). As a point of reference, I do not have any Android or Google OS devices.
Message 135 of 335
sleepr88
Apprentice
TP-link, Linksys, and others have already gotten it fixed... How long for a Chromecast/Android fix Netgear?
Message 136 of 335
ajshurts
Apprentice
I have to reset my router every 24-48 hours and it is running in AP mode so the system is not even doing any heavy lifting.  I am pretty much done with this system.  I work from home and I can't trust it to not crash on me during a critical meeting.  It's frustrating because it seemed to have worked well for a while and then firmware update after firmware update, I just run into new problems.
One of the updates took me completely offline, one screwed up my DNS resolution, these last few have been the consistent daily or every other day crashing.  For the cost of this system, I don't expect these kinds of issues.  I had an Asus RT-N66U which just worked, forever, no crashes, 24 hours a day, every day.  The only thing it was lacking was Wi-Fi range.
Message 137 of 335
robertcdh
Apprentice
I just got the beta update for Google Play Services on both our Android phones.  So, I went ahead and plugged-in our Google Home and Google Minis that have been unplugged for over a week.  I'm happy to say that it appears that the update fixed the reboot issue.
Orbi firmware: 2.1.2.18
Google Play Services:  11.9.75 beta
I still hope Netgear updates its firmware to prevent future issues like this one from rebooting the router.
Message 138 of 335
RogerSC
Virtuoso
Just a quick thing...noticed that my desktop (that's currently plugged into a port on the Orbi router unit) lost internet earlier today, first time in a long time. Looked at it, and the light was showing magenta, isolated, not sync'd with the satellite. Satellite wasn't showing any light at that point. So I immediately thought of "loss of sync" of the router unit as a possibility, pressed the "Sync" button the back of the router unit. Within about a minute, the router unit was back in sync with the rest of the world. No further problems in the hours since, everything fine again.
Thought I'd mention that in case it might help anyone else at some point.
Good luck out there!
Message 139 of 335
harald77
I got the same reply, which is: "This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I am not able to update the firmware in neither the online update nor the manual update tab under firmware update. I am very certain I have tried downloading the firmware for my RBS40 sat. The filename used is RBS40-V2.1.2.18.img.
Any suggestions for how to solve this?
Model: RBS40| Orbi AC2200 Tri-band WiFi (Add-on Satellite)
Message 140 of 335
GEB222
Guide
Almost the same here :
Firmware check shows :
"Router RBR40 : RBR40 V2.1.2.18 No new firmware version available."
"Satellite RBS40 : Orbi Satellite-1 V2.1.1.16 Service unreachable"
and no way to update satellite manually ("This firmware file is incorrect! ...")
Message 141 of 335
iJester
Initiate
@GEB222
1. Manually download V2.1.2.18 firmware for the satellite from here:  https://www.netgear.com/support/product/RBK40.aspx#download.
2. Navigate to orbilogin.com in a broswer.  Log into orbi and find the satellite IP address in GUI.  Satellite IP address is shown under attached devices.
3. Navigate to http://Satellite IP/fwUpdate.htm in a broswer.  Log into orbi and browse to the location where you downloaded the firmware and install.
Message 142 of 335
harald77
Thank you for your reply iJester, but still it returns the same error message in my case:
The uploaded file I used was RBS40-V2.1.2.18.img for my RBK40 satellite, which I believe is an RBS40. Perhaps there is something wrong with the file?
Message 143 of 335
note8guy
Guide
I had the same probelm this morning after waking up my phone (Note 8).  The router just kept rebooting each time i tired to use the WIFI.  I turned up the WIFI radio on the phone and the router has been stable for 1.5hrs so far.
I updated to 2.1.2.18 yesterday afernoon, plugged back in my chromecast and goolge home devices and this ran well untill this morning.  I had hoped the new frimware would have some protection to prevent it from restarting. I'll reboot my phone and look into the beta for Goole play services and see if the same  thing happends again.
Hey Netgear I'm sure you have tons of data on this but if you need any logs or dumps let me know.
Message 144 of 335
PhiloF
Tutor
I just bought an Orbi100 kit. I upgraded to firmware RBR50-V2.1.2.18 and RBS50-V2.1.2.18
The Wired Satellite backhaul has an irregular response.  Have other users encountered the same problem? I'm the only device connected to the 5g; WiFi scan shows no other network on that frequency.
This is a sample ping from wireless client to satellite RBS50:
MACBOOKPRO-C8A8-298:~ philippeflichy$ ping 192.168.223.121
PING 192.168.223.121 (192.168.223.121): 56 data bytes
64 bytes from 192.168.223.121: icmp_seq=0 ttl=64 time=2.133 ms
64 bytes from 192.168.223.121: icmp_seq=1 ttl=64 time=2.346 ms
64 bytes from 192.168.223.121: icmp_seq=2 ttl=64 time=2.372 ms
64 bytes from 192.168.223.121: icmp_seq=3 ttl=64 time=3.092 ms
64 bytes from 192.168.223.121: icmp_seq=4 ttl=64 time=4.352 ms
64 bytes from 192.168.223.121: icmp_seq=5 ttl=64 time=2.804 ms
64 bytes from 192.168.223.121: icmp_seq=6 ttl=64 time=108.457 ms
64 bytes from 192.168.223.121: icmp_seq=7 ttl=64 time=72.484 ms
64 bytes from 192.168.223.121: icmp_seq=8 ttl=64 time=58.553 ms
64 bytes from 192.168.223.121: icmp_seq=9 ttl=64 time=1.915 ms
64 bytes from 192.168.223.121: icmp_seq=10 ttl=64 time=1.409 ms
64 bytes from 192.168.223.121: icmp_seq=11 ttl=64 time=392.419 ms
64 bytes from 192.168.223.121: icmp_seq=12 ttl=64 time=1.775 ms
64 bytes from 192.168.223.121: icmp_seq=13 ttl=64 time=2.198 ms
64 bytes from 192.168.223.121: icmp_seq=14 ttl=64 time=1.757 ms
64 bytes from 192.168.223.121: icmp_seq=15 ttl=64 time=2.186 ms
64 bytes from 192.168.223.121: icmp_seq=16 ttl=64 time=1.440 ms
64 bytes from 192.168.223.121: icmp_seq=17 ttl=64 time=2.411 ms
64 bytes from 192.168.223.121: icmp_seq=18 ttl=64 time=2.248 ms
64 bytes from 192.168.223.121: icmp_seq=19 ttl=64 time=103.525 ms
64 bytes from 192.168.223.121: icmp_seq=20 ttl=64 time=85.235 ms
64 bytes from 192.168.223.121: icmp_seq=21 ttl=64 time=76.098 ms
64 bytes from 192.168.223.121: icmp_seq=22 ttl=64 time=63.008 ms
64 bytes from 192.168.223.121: icmp_seq=23 ttl=64 time=2.546 ms
64 bytes from 192.168.223.121: icmp_seq=24 ttl=64 time=2.155 ms
64 bytes from 192.168.223.121: icmp_seq=25 ttl=64 time=1.955 ms
64 bytes from 192.168.223.121: icmp_seq=26 ttl=64 time=2.596 ms
64 bytes from 192.168.223.121: icmp_seq=27 ttl=64 time=2.144 ms
64 bytes from 192.168.223.121: icmp_seq=28 ttl=64 time=2.824 ms
64 bytes from 192.168.223.121: icmp_seq=29 ttl=64 time=1.368 ms
64 bytes from 192.168.223.121: icmp_seq=30 ttl=64 time=2.640 ms
64 bytes from 192.168.223.121: icmp_seq=31 ttl=64 time=1.688 ms
64 bytes from 192.168.223.121: icmp_seq=32 ttl=64 time=2.983 ms
64 bytes from 192.168.223.121: icmp_seq=33 ttl=64 time=73.367 ms
64 bytes from 192.168.223.121: icmp_seq=34 ttl=64 time=36.703 ms
64 bytes from 192.168.223.121: icmp_seq=35 ttl=64 time=110.634 ms
64 bytes from 192.168.223.121: icmp_seq=36 ttl=64 time=1.947 ms
64 bytes from 192.168.223.121: icmp_seq=37 ttl=64 time=1.873 ms
64 bytes from 192.168.223.121: icmp_seq=38 ttl=64 time=2.265 ms
64 bytes from 192.168.223.121: icmp_seq=39 ttl=64 time=2.823 ms
64 bytes from 192.168.223.121: icmp_seq=40 ttl=64 time=2.033 ms
64 bytes from 192.168.223.121: icmp_seq=41 ttl=64 time=1.616 ms
64 bytes from 192.168.223.121: icmp_seq=42 ttl=64 time=2.695 ms
64 bytes from 192.168.223.121: icmp_seq=43 ttl=64 time=123.573 ms
64 bytes from 192.168.223.121: icmp_seq=44 ttl=64 time=3.054 ms
64 bytes from 192.168.223.121: icmp_seq=45 ttl=64 time=6.431 ms
64 bytes from 192.168.223.121: icmp_seq=46 ttl=64 time=2.637 ms
64 bytes from 192.168.223.121: icmp_seq=47 ttl=64 time=117.351 ms
64 bytes from 192.168.223.121: icmp_seq=48 ttl=64 time=30.336 ms
64 bytes from 192.168.223.121: icmp_seq=49 ttl=64 time=13.624 ms
64 bytes from 192.168.223.121: icmp_seq=50 ttl=64 time=1.602 ms
64 bytes from 192.168.223.121: icmp_seq=51 ttl=64 time=2.717 ms
64 bytes from 192.168.223.121: icmp_seq=52 ttl=64 time=2.014 ms
64 bytes from 192.168.223.121: icmp_seq=53 ttl=64 time=2.057 ms
64 bytes from 192.168.223.121: icmp_seq=54 ttl=64 time=3.341 ms
64 bytes from 192.168.223.121: icmp_seq=55 ttl=64 time=1.534 ms
64 bytes from 192.168.223.121: icmp_seq=56 ttl=64 time=2.675 ms
64 bytes from 192.168.223.121: icmp_seq=57 ttl=64 time=125.058 ms
64 bytes from 192.168.223.121: icmp_seq=58 ttl=64 time=108.228 ms
64 bytes from 192.168.223.121: icmp_seq=59 ttl=64 time=90.566 ms
64 bytes from 192.168.223.121: icmp_seq=60 ttl=64 time=2.118 ms
64 bytes from 192.168.223.121: icmp_seq=61 ttl=64 time=1.877 ms
64 bytes from 192.168.223.121: icmp_seq=62 ttl=64 time=1.315 ms
^C
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 145 of 335
cmftblynu
Star
I am seriously going to contact a lawywer about this.  Netgear is pushing this update, I have had to downgrade this firmware 3 times, it keeps pushing.  EVERYTIME it pushes IT BREAKS MY ENTIRE HOUSE... no wired connections work correctly, and I have a switch that controls over 16 wired connections.  THIS IS UNACCEPTABLE.  Nothing that netgear does for a FIRMWARE update that should break everything behind a netgear switch.  This makes no logical sense.  This breaks my house every time.  I keep downgrading it, then I go in and change my NVRAM so the router is not supposed to update, but somehow it updated.  Does the NVRAM reset if the power goes out???!?  At least I was able to manage this by keeping the router from breaking itself with its own stupid firmware update, Netgear you need to get your SH$%T together.  This is going to get you sued.  People cannot work from home.
Message 146 of 335
AncientUser
Updated to 2.1.2.18 yesterday and woke up to no wifi at all this morning.  Rebooted router a couple of times and finally had wifi, but no satellite.  Have tried everything including factory reset of both the RBR50 and the RBS50.  Did initial setup twice and it keeps saying "satellite not found".  Moved RBS50 into same room as router, but it still won't sync.
At 76 years old, trying to get our wifi at a reasonable speed is not my idea of how I want to spend my time.
Anything else that I can try?  Don't know if using an earlier firmware will solve the problem and don't know how to go back to an earlier version.
Thanks for any help you can give.
Message 147 of 335
aani75
Apprentice
I KNOW GOOGLE FIXED THE ISSUE AND PUSHING IT TO DEVICES BUT NETGEAR, I CANNOT CHECK EACH AND EVERY DEVICE FOR THE ISSUE. YOU HAVE TO RELEASE A FIX FROM YOUR END TO MAKE SURE NO-ONE WITH ROGUE DEVICE COULD SHUTDOWN YOUR PRODUCT'S MAIN BUSINESS, NETWORK. IT SEEMS LIKE YOUR ORBI SYSTEM CAN TAKE CARE OF DOS- ATTACK BUT NOT THIS ANDROID OR PACKET BURST ISSUE.
ANY ROGUE DEVICE COULD SEND A BURST OF PACKETS, AND THAT IS WHAT ALL IS NEEDED TO SHUTDOWN THIS PREMIUM PIECE OF SH***T NETWORK GADGET. SOME MEDIOCRE
NAME LIKE TP-LINK ALREADY PROVIDED THE FIX AND YOU COULD NOT, SHAME ON YOU NETGEAR.
Model: RBK43| Orbi AC2200 WiFi System, RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 148 of 335
webminster
Luminary
Yes, I have the irregular ping times on local network as well.   2.1.2.18 so far has been better than 2.1.1.16 and 2.1.2.10, which actually appeared to drop pings (may have actually been just way-too-long returns).
I think others have observed similar issues on wide variances of ping response times.  I've compared the tests to previous ASUS router, it definitely originates in the Orbi.  Either some QoS issue or something - I have tested same when connected to the router instead of satellite, and also get the variances - just not quite as bad as when going through the satellite.
Message 149 of 335
PhiloF
Tutor
Thanks for confirming! I have the same amount of drops when connecting to the main unit. It is so bad that I have audio drops I never encountered this with my previous Apple system... Wondering if I should send all these supposed marvels back to Amazon .... The coverage and the signal are definitely very good but what's the point if I cannot listen to my music ?)
Message 150 of 335
Top Contributors
Announcements
Orbi WiFi 7
