Orbi WiFi 7 RBE973
Reply
New Orbi not connect to WiFi on pc
Barbwireless
Follower
After set up, Apple products worked OK. PCs cant connect. When I put the password in the reply comes back can't connect to this network.
Kindle says authentication problem.
Help, please.
Message 1 of 2
Guru
Re: New Orbi not connect to WiFi on pc
Did you set up a custome SSID name and PW?
Be sure you forget any prior wifi profiles in the PCs network settings.
Be sure your using WPA2 and AES wifi security settings on the RBR. Use as web browser to check the RBRs web page.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 271 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
