- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New firmware but not more able to connect to wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just had an automatic firmware update. (to 1.12.0.18 I think).
I found out because I had an authentication error on my wifi. While looking at the settings, I saw I had a new firmware update. I restarted router and satelite. Changed wifi to the need of no password, reset the router to factory settings... And finally manually installed the version 2.0.0.72 I found on the netgear website, after reading about multiple problems with previous firmwares.... And ... still not able to connect to wifi.
At last, I found the solution: restart my phone and suddenly I could reconnect again.
Lesson ; after firmware update, when you have problems with the connection of your phone (and maybe other devices), restart the phone (or devices).. Everything works now 🙂 At last, I have the latest , newest firmware now 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New firmware but not more able to connect to wifi
Yes, after changing your router or resetting it, you should make all devices forget the network and reconnect the device, I however would strongly advice you against using "No password needed" as an option, anyone could use your network for malicious reasons included but not limited to hacking your network or doing criminal activities on your behalf.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyway, now everything is working, with password 😀. I only added my message in case someone else was in the same situation as I was.
Greetings
Stefan
